Results 1 to 6 of 6
Thread: Hibernation issues
    Question Hibernation issues
    Hi Guys,
    I ran for a long time with Mediacar and a fairly early version of MM. In fact I think it was still called D3.
    I then switched up to RR and the latest MM. Since then although improved functionality is great, I am having situations where intermittantly the computer isn't hibernating after I switch the ignition off (Opus 150).
    I have tried closing RR and MM before trying to enter hibernation and that works fine, as does having RR open but MM closed. Therefore I think it is probably MM causing the issues.
    Anyone have similar problem, or any suggestions to what might be causing it...??
    Matt
    Jun 2004
    The North, Manchester
    gps reciever?
    Low Bitrate F4kk3r0's Avatar
    Mar 2004
    Finland
    My carputer gets somehow confused after returning from hibernation when I use MM. The resolution goes to some 640X480 and the colors gets something like 16. Wonder what does this?
    Phone Control Moderator Chaos_666's Avatar
    Oct 2004
    Germany
    Hi there
    Quote Originally Posted by Matthew230
    Hi Guys,
    Matt
    I have the same problem when using Freedrive in RR. If i hibernate from RR nothing happens. If i did not start FD before system is going down fine.
    Do you use a BT-GPS? Maybe that is our poroblem?
    THX
    Chaos
    Jul 2004
    All I would like to request .. is that MM is quiet first 10 seconds after resuming from hibernation - it always says something unecessary like "gps not found" og "check antenna" , and right after that , it finds the GPS anyway and the satellites..
    Quote Originally Posted by Chaos_666
    Hi there
    THX
    Chaos
    I use that cheap GPS receiver from ebay, - http://cgi.ebay.co.uk/ws/eBayISAPI.d...786684943&rd=1
    If that is the problem, how is it fixed ??
    Matt
  1. Replies: 4
    Last Post: 10-10-2005, 01:56 PM
  2. iGuidance Hibernation - Interesting Issue
    By Troy McClure in forum GPS
    Last Post: 06-11-2005, 03:16 AM
  3. I'v had a thought! - Make Hibernation Better?
    By mick-uk in forum WinNT Based
    Last Post: 05-19-2005, 09:39 AM
  4. Odd Off Topic-ness on Hibernation
    By Vchat20 in forum General MP3Car Discussion
    Last Post: 01-31-2005, 06:41 PM
  5. Hibernation Issues
    By Maeveth in forum Centrafuse
    Last Post: 01-23-2005, 01:36 PM
