Results 1 to 10 of 18
Thread: Destinator PN
    Constant Bitrate lanman1's Avatar
    Dec 2004
    SC
    Destinator PN
    I have several users that use MM/Destinator3 for USA/European travel and everything has worked very well. That is, until I tried to add one more user. I ordered another copy of D3 and received Destinator PN which according to them is just a new name for D3. The maps however immediately cause an 'illegal operation' error in MM. Upon closer inspection, these new maps also include 2 new files(Default.ldm and MapStreetTypes.TXT). Anyone have this behavior? Have they changed the Map format? I really want to stay legal with this but it's my butt on the line if I can't get this guy's laptop working soon.
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Try running just Destinator with the new maps and not MM and see if you get the same action. C_client.exe
    Mar 2005
    Destinator PN is not the same as Destinator 3 !!!!
    PN is the new version used to have the code name "Destinator 5"
    May 2005
    Glasgow, Scotland
    How will we get map data in the future?
    Had a look on a couple of map shops and it looks like none of them have D3 in stock.
    Most of them sell Destinator PN instead. If this map data can't be used with MM, how will we be able to get updated map data in the future?
    / Micke
    Mar 2005
    PN version is capable to read version 3 maps.
    I assue the other way also work.
    FLAC mauri's Avatar
    Jan 2004
    Boys, please,who has purchased Destinator PN us shapeless to all of us if the maps somehow can work with MM, otherwise is it one big problem for us "to be update" in the future !
    Mauri
    Dec 2004
    SC
    MM will not open PN maps. It produses an immediate windows error when You try to switch to one. D3 maps (US and Euro) work fine.
    Jul 2005
    if you remove the file WCE_B2.dat than you can load the maps. but navigation does not work. i try to make a new maps with Destinator PN cutter. only greece map do work from PN CD. the other not.
    someone any idea - how to integrate PN Maps?
    Jun 2005
    FYI: I can use a cut map from PN in the Destinator sample app without changing anything. The navigate and all other functions work fine too.
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by lauren
    Good, please, infos step by step for use the PN maps in MM...
    Mauri
