Results 1 to 2 of 2
Thread: Map Monkey SDK
    Jun 2005
    Map Monkey SDK
    Hi,
    I bought the Destinator Maps and SDK.
    I downloaded Map Monkey (tested it and it runs fine)
    When i run the VB6 example program provided, I get "Map Monkey not started". I cannot get around this, either running the .EXE or in the environment. Any ideas?
    Russ
    Raw Wave
    Jun 2004
    On the beach
    You need to enable remote access in Map Monkey by looking in settings.ini, I think it is:
    remote=true
    port=7901
    or similar, I'm sure a quick search on here will tell oyu exactly, or alternatively look in the documentation for the Map Monkey SDK.
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Map Monkey sdk center map command....
    By feelgood in forum Map Monkey
    Last Post: 05-28-2005, 07:31 AM
  3. Map Monkey SDK not working
    By fromplanetbob in forum Map Monkey
    Last Post: 05-17-2005, 06:27 AM
  4. Replies: 0
    Last Post: 02-14-2005, 11:01 AM
