Results 1 to 8 of 8
Thread: Poi DAT Format
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    Poi DAT Format
    For NinjaMonkey:
    I want to create an utility to convert ov2 (TomTom Poi) into dat format. I see that you add the "import" function for speed camera cvs; so you may know how the dat format is. Can you post something? Maybe the piece of code that create the dat file.
    Thanks a lot,
    Garo
    Newbie PuppinoCbr's Avatar
    Jun 2005
    Italy
    Come on garo e NinjaMonkey!! We are waiting for your works!!
    Jan 2005
    Milan, Italy
    A thread is already talking of this on FreeDrive forum:
    http://www.mp3car.com/vbulletin/freedrive/53589-poi-dat-format-post549047.html
    However it is valid for both FreeDrive and MapMonkey, look at it!
    Jun 2005
    Italy
    Thank you!! I'll look at there!
    Jun 2005
    Italy
    Dear garo Ok, for this.. i've tried your soft. and is all ok!! Thanls!! 2 little questions:
    1) According to you, putting many .ini of favorites (es. many categories of fuel stations, hospitals.. etc then i mean the primary categories that contain the single places), if they are not selected (for viewing) in favs page, weight down and slow down MM the same?
    2) Do you know how to import the BMP personalized images for Favs? i have tried everything!! i have done the same size (16x16x24bit) nothing! called it the same name of .ini, nothing I have seen too that, when i open MM and i see in Favs and to choose an image, the personal image isn't in favs and when i close the program and i see in favs dir, the small images there isn't any more and, with the same name, there is now a random image with the same name of bmp duplicated..
    Can you help me?
    Thanks again!!
    Jan 2005
    Milan, Italy
    Hi!
    1) No, they slow down MM only when you want to navigate towards them... I mean, it is very slow when the list of POI appears on the screen, because MM don't "select" near POI, but all of them.
    2) I didn't use .ini... I just put the .dat file in the favorites folder and the corresponding .bmp (with the same name). Furthermore, I used bigger bmp files and they worked fine!
    Bye!
    Jun 2005
    Italy
    Sorry garo!! i have mistaken.. i meant ".dat", no ".ini" sorry!
    Well, i put in favs dir .dat and .bmp with the same name but.. i can't see the bmp images in MM and choose it what kind of problem might be?
    Thanks and bye!!
    Jun 2005
    Italy
    For Bmp not correctly visualized in the page of favs, i've seen that, if i use a name that begins with letters near firsts letter (es. "A", "B" .. i don't know within letter but i know that "E" is ok but just "I" is not correctly visualiz.)..
    And so, i've renamed all Favs added with this criterion : all names begin so (es.) "- Hotel" "- Restaurant"... .of course, .dat and .bmp must have the same name In this way, seem work
    Bye all!
  1. Replies: 6
    Last Post: 02-22-2005, 02:11 PM
  2. Universal Skin Format
    By liquid_smoke in forum Software & Software Development
    Last Post: 02-01-2005, 01:08 AM
  3. D3 POI is well $uck
    By MatrixPC in forum Map Monkey
    Last Post: 01-14-2005, 03:46 PM
  4. Replies: 2
    Last Post: 09-08-2004, 07:59 AM
  5. MP3 or RealOne format? Both Supported in WinAmp & MediaEngine?
    By -al- in forum Software & Software Development
    Last Post: 09-18-2003, 02:57 AM
