Page 1 of 3 123 LastLast
Results 1 to 10 of 22
Thread: Map Monkey doesn't understand roundabouts.
    Newbie bigmac999's Avatar
    Jan 2005
    UK
    Is this a common thing or just my set up?
    When using navigation in Map Monkey, it doesn't seem to grasp roundabouts. If I need to go straight on, it always says turn right. It just doesn't seem to understand roundabouts, which is very frustrationg as it means I have to look at the screen all the time to double check if it actually is turn right or straight on.
    Also, often when travelling along a straght road, and approaching a t junction, it says keep right, which seems uneccassary and sometimes confusing as I'm just staying on the same road.
    Are there any fixes for these, as unless I keep looking at the screen to double check (which is dangerous for obvious reasons), I find it's sending me off in the wrong direction.
    Any ideas?
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    I have heard these complaints before.... I dont think there is a workaround....
    If there is an exit to the right on a main road, and you should stay on this main road (i.e. not go out to the right) destinator will always tell you to keep left....
    As for the roundabouts I dont think it graps the concept of a roundabout and basically want you to turn "right" out of the roundabout instead of going "straight -through- the roundabout"....
    maybe newer maps for your area eliminate some problems
    Roy
    2005 Range Rover 4.4
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    These are symptons of where roads have changed over years,
    ie a roundabout added to once there was a crossroads.
    The priority of roads have changed ie what was once a turning off has now become the main route and the main route that was is now a side road.
    These may not have happened recently either, it may have happened many years ago, but because the name of the roads are different the software thinks it is a turning.
    Bear in mind the people who create the maps don't travel these roads personally so they may not know all the local nuances.
    Jan 2005
    UK
    I see what your saying, but it does it on every single roundabout.
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    That's a problem with your maps
    Some of the earlier 2003 maps have a bug where roundabouts will be ignored. Get the newer 2004 maps and all will be well
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Jan 2005
    UK
    Excellent stuff, I'll try that. Thanks.
    Jan 2005
    UK
    Does anyone know the best place to get updated maps from?
    FLAC sdashiki's Avatar
    Aug 2004
    Floreeda
    had to chime in:
    What does everyone call Roundabouts where they are from?
    Rotaries are found in New England
    (All done)
    iPad Mini 128GB, RF 600.5 amp, JL12W0V2, 8 Infinity Components
    Raw Wave Laidback's Avatar
    Oct 2003
    Madrid
    Quote Originally Posted by Enforcer
    Yes they do!
    http://www.pocketgpsworld.com/navteq.php
    NavteQ - Nice to see...
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Replies: 106
    Last Post: 10-20-2008, 10:09 AM
  3. Anyone using Map Monkey 1.1.3 with Deluo USB GPS?
    By Chita79 in forum Map Monkey
    Last Post: 02-04-2005, 02:06 AM
  4. Replies: 3
    Last Post: 02-03-2005, 01:11 PM
