Results 1 to 6 of 6
Thread: Copying Map Monkey to new laptop
    UHF
    UHF is offline
    Jan 2005
    I just downloaded map monkey from the website for my new laptop, copied my maps over from my old one and also copied the dll file and every time i try to switch maps I get the built in blue screen saying that the map is damaged, very confused?
    I've tried a straight directory copy between laptops and that dont work either yet it loads perfect on the old one!
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    See FAQ... Duff DLL problem me thinks...
    Terran
    UHF
    UHF is offline
    Jan 2005
    even tho its a direct copy from another working laptop?
    Raw Wave
    Jun 2004
    On the beach
    Did you reinstall MapMonkey or just copy it over??
    Jan 2003
    Try Freedrive - do you still have the same prob with the same map ? If so must be the map..... if not it will be the MM install.
    Terran
    Raw Wave RoyN's Avatar
    São Paulo, Brazil
    did you register the dll? if I recall the MM packs dont have a DLL anymore (at least at some point they were removed), so you copy the dll over to c:\DestinatorApps\Destinator\DestDLL.dll, and then run "regsvr32 c:\destinatorapps\destinator\destdll.dll"
    Roy
    2005 Range Rover 4.4
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 10:27 AM
  2. Replies: 106
    Last Post: 10-20-2008, 09:09 AM
  3. Anyone using Map Monkey 1.1.3 with Deluo USB GPS?
    By Chita79 in forum Map Monkey
    Last Post: 02-04-2005, 01:06 AM
  4. Replies: 3
    Last Post: 02-03-2005, 12:11 PM
