Results 1 to 10 of 12
Thread: Comm Port In Use!
    Mar 2005
    Melbourne, AUS
    Comm Port In Use!
    Hey, I have been using MM in my car with a BU-303 reciever and MM has been working brilliantly. Yet, sometimes when I load up MM I get the message saying that -the comm port is in use-, this leads to the GPS reciever not being detected by MM. On most occasions MM states that it is reconnecting the GPS and everything works fine. On the occasions it doesn't work even closing MM and then reopening it makes no difference. does anyone know how to fix this problem?
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by smkau18
    See in your system if have setting in "device manager" utility one "serial mouse" ....disable this.
    The GPS COM is settings to 4800 Baud?
    Mauri
    Mar 2005
    Melbourne, AUS
    ok thanks will give it a try
    Mar 2005
    Melbourne, AUS
    mauri
    I had a look and couldn't find "serial mouse" in the "device manager"
    any other ideas?
    FLAC mauri's Avatar
    Jan 2004
    Another serial device connects?Type Touch screen no USB but Serial for exsample....
    Is is possible to launch correctly "Yperterminal" or no?
    Mauri
    Mar 2005
    Melbourne, AUS
    mauri
    sorry I don't quite understand what "Yperterminal" is
    May 2005
    I have this same problem, i would be pleased to know of a solution
    FLAC mauri's Avatar
    Jan 2004
    HyperTerminal is it one emulation port sw by Windows,embedded from W98 to XP !
    Start
    Programs
    Accessories
    Communications
    HyperTerminal
    Lauch this,set the COM if you use for the GPS (connected) 4800baud,N,8,1,no control ....you see the GPS NMEA infos in real mode if work.
    If the Hypert. is it impossible to launch correctly(and same infos of COM is used), you have one serial device in your system hide...
    EDIT:you have check in the original D3 GPS settings?
    Don't set the same COM real port that uses with MM, can have some conflicts so change it... don't use with MM the original utility of GPS settings by D3 .
    Mauri
    Feb 2005
    Guys, search before you post.
    anyway, i had the same problem, and i tried all of the above. at the end, the solution was much simpler, you wont believe it. i switched the usb ports, literally. took it out and stuck it to the other usb port.. dunno why, it worked, i guess bill gates knows..
    try it.
    Mar 2005
    Melbourne, AUS
    thanks for all the advice mauri and omernesh. I have been away from the computer over the weekend due to work. I will try and give it a go tonight
  1. USB port power dies?!
    By pixelflash in forum General Hardware Discussion
    Last Post: 10-22-2007, 10:26 AM
  2. Replies: 4
    Last Post: 07-04-2005, 05:38 AM
  3. [Release] iGSkinner BETA 3.9.5
    By 0l33l in forum SkinBedder
    Last Post: 06-26-2005, 03:40 PM
  4. OSK clobbers comm port?
    By wi77iam in forum Software & Software Development
    Last Post: 03-25-2004, 12:12 PM
  5. Via Mini-ITX Epia 5000 serial port not working
    By vash in forum General Hardware Discussion
    Last Post: 08-13-2002, 09:48 PM
