Results 1 to 1 of 1
Thread: Another utility : convert .DAT to .CSV
    FLAC mauri's Avatar
    Jan 2004
    Thumbs up Another utility : convert .DAT to .CSV
    I have added one another utility to the other two posteds in this link:
    Two utility for convert to .dat file
    This converts the files .DAT ( D3 compatible) to .CSV and contrarily .CSV to .DAT
    Read for use:
    it selects to the left the type of file. DAT as example as source to be converted, and you make the search with " input file "
    it selects to the right the type of file. CSV as example as file final convert, and you make the search with " Output file "
    Click on " START " button
    If everything all ok, you have the converted file saved in the same directory of the rising file.
    Good job
    Mauri
    Attached Files Attached Files
  1. Utility to change behavior of ATX power button (e.g.: launch an app)
    By justintime in forum Software & Software Development
    Last Post: 05-08-2009, 05:45 PM
  2. Two utility for convert to .dat file
    By mauri in forum Map Monkey
    Last Post: 03-12-2008, 12:35 AM
  3. LCD driver/bios development utility?
    By GRUNT in forum LCD/Display
    Last Post: 06-11-2005, 07:59 PM
  4. How to convert from Hirose to RCA????
    By AVOGODRO in forum LCD/Display
    Last Post: 11-29-2002, 11:24 PM
