2005.Q1 works fine in D3 for me.
Originally Posted by löwe
i have the 2004.q4.3318 & NOT WORKING !( PN VERSION)
Roy
2005 Range Rover 4.4
I have 2005 Q2 here (australia)
yet to test in freedrive / mapmonkey
currently running 2004 Q4
PS: my 2005.Q1 maps were not modified/cut/files deleted/anything... i just popped them into a folder and it worked without problems...
Roy
its the pn versionOriginally Posted by illo41100
just usw the destinator pn hack
and it works
What is the destinstor PN hack and where can I get hold of it?
in ur map delet "WCE_b.dat"
after this cut ur map new with mapcutter
also see How to insert the Dest. PN maps in Dest. 3?
why this "hack" is NOT added in MM ?????
Is a big problem or not ?
Originally Posted by RoyN
Pn version ? fully functional ? ( view & planning the route ? )
@illo, I am using the Maps, not destinator pn engine, so view/plan isnt changing... I use FreeDrive, not MM, so I didnt test with map monkey.
I dont see how usefule it would be to add this to MM, it is a minor problem and it is the consequence of using a wrong map version (newer) than the engine used in MM (destinator 3)...
DestinatorPN sdk isnt stable yet to use, so it will take a little while before it works correctly on the new maps.
Roy
