Results 1 to 5 of 5
Thread: MapMonkey and Delphi Example
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    Can anyone send me an example in D6 working with MM? I've been through the threads here, had it working at one point then it stopped completely. Ideally I'd like an example that displays the latitude/longitude and/or directions but anything would be a plus right now.
    Chris.
    My Village Called 0l33l's Avatar
    Jul 2004
    Berkeley, CA
    Using the dll or winsock
    Let me find em on my HD.
    Jul 2004
    Berkeley, CA
    Code:
      if frmCommandAndControl.MM.IsMapMonkeyRunning = True then begin
      if frmCommandAndControl.MM.Connected = False then ConnectToMM;
      frmCommandAndControl.MM.ShowRoute;
    procedure ConnectToMM();
    var
      Word: WordBool;
      t: TOleEnum;
    begin
      word := True;
      frmCommandAndControl.MM.Connected := word;
      t := ThreadSync;
      frmCommandAndControl.MM.ThreadMode := t;
    end;
    Nov 2003
    Massachusetts
    Using the DLL, hopefully. I'll try this later, thanks!
    Nov 2003
    Massachusetts
    Okay so I have this:
    Code:
    var
      Word: WordBool;
      t: TOleEnum;
    begin
      word := True;
      Form1.MM.Connected := word;
      t := ThreadSync;
      Form1.MM.ThreadMode := t;
    end;
    procedure TForm1.Timer1Timer(Sender: TObject);
    var
      Word: WordBool;
    begin
            if Form1.MM.Connected = False then ConnectToMM;
            if mm.IsMapMonkeyRunning = true then
                    Begin
                    label1.caption := 'connected';
                    If mm.connected then label2.caption := 'xx';
                    If mm.connected then label3.caption := mm.Version;
                    End
            else
                    Begin
                    label1.caption := 'not connected';
                    End;
    end;
    I see label 1 show "Connected" but Label2 and Label3 never change, i.e. mm.connected is never true. Should I care? If I rey and access properties without it connected I get "not connected" errors.
    Thanks,
    Chris.
