The same for me! And you DON'T have VS, right?Originally Posted by RoyN
Yeah, destinator.exe just hangs for me after giving a select map dialog, and then I get a "send error report" dialog....
Roy
2005 Range Rover 4.4
I have VB6.... it installs into what it calls "Visual Studio 6.0"... no VS2003
Roy
Ok, so it's no VS2003 faultOriginally Posted by RoyN
Do you have Office 2003?
Yep, Office 2k3 is here... could this be breaking D5?
I dont have office on the carpc, should I try it there???![]()
Roy
I'm thinkin about everything... It's the only thing those pcs have in common, at a first glance! If you can try... try!Originally Posted by RoyN
I confirm it works on one of my carpcs!
No VS2003, no Office2003... dunno what else might make a different at this stage.
Didnt find out too many improvements.... c_client.exe didnt work, only destinator.exe... my map didnt work too cause it said it had to register it, I didnt want to risk anything since this isnt the final SDK I'm thinking...
I guess the problem might not be the SDK itself, just something that is "breaking" the sdk/demo-app...
Roy
Originally Posted by CdRsKuLL
I always like fixed files so if anyone wants to hook a brother up?
ps also don't mind some of those 'broken' kind.
Maybe this is old news to everyone but; my last correspondance with Rafiq was on 9/26; I assume that nothing much has changed; an excerpt of my email (from Rafiq):
"Our developers are still working on the issues for SDK V5. There are a few bugs which have come to light and they are working on fixing them. They have not given us a timeline just yet as some bugs require major work."
With the above in mind:
I have been able to do the following on some machines (others give a memory access error):
Ran the destinator.exe that comes with it; but it won't open up Dest PN maps; asks for a registration.....
Tried to run vb; but get automation errors when trying to create the activex object; I spent days trying to figure this out; so I went to the c example instead.... thought maybe I could get it to work....
Compiled the c_client; with the same results (asks for a registration). The original c_client requires modifcation to make it compile; then rafiq sent me a another version; and it required still more mods to make it compile and run (regarding the threading model for the active x). This was when I decided that there were bigger issues with this SDK than just me not programming it right; I sent Rafiq a list of issues (maybe 3 monthes ago????); and about once a month I have been getting an update from himof course usually they are just wait a little longer..... nothing has changed. msgs like the one above....
Hope this info helps. They did offer to give me the D3 sdk until they fixed the D5 one; but I really don't need that. Esp since I don't have D3 maps (only PN).
Tnx a lot, I didn't undestand this, now it's clear...
So, let's wait for a working version... I WANT IT![]()
