Here is what I received yesterday (Feb,10 2006)
Hello,
Map Monkey will not work with the Destinator
software. Others in the past were using another dll file in order to get it to work. However that file was a temporary file that was to be used by developers for
testing created applications in the local areas. The file was being used by others for other purposes. The expiry date on that file was Aug 04 and was only for SDK V3. We no longer support SDK V3 as we have moved to SDK V5.
If you want to create your own application that will run on a PC you will need to purchase our SDK V5. With SDK V5 you can create your own application which will allow you to run it on a PC.
I hope this helps.
Rafiq
-----Original Message-----
Sent: February 10, 2006 12:55 AM
To: Rafiq Kassam
Subject: Destdll_08_05.zip -
hi,
I know this question raised thousand times. I bought a destinator PN map and want to use Map Monkey. How and where to purchase the right sdk or dll file?
Please guide me to the right direction.
