Results 1 to 3 of 3
Thread: Anyone using MM and NMEA Compass/XPort2?
    FLAC ukchris's Avatar
    Nov 2003
    Massachusetts
    MapMonkey doesn't seem to see the XPort2 ports even though other apps do (Routis for example). Any ideas how to get MapMopnkey running with a shared COM Port?
    Chris.
    lez
    lez is offline
    FLAC lez's Avatar
    Jan 2004
    UK
    No but was planning to........
    What if you run destinator direct, same problem ??
    Maximum Bitrate Don 944 LA's Avatar
    May 2004
    San Diego / Los Angeles
    I run it with MM.. works fine
    make sure MM is in advanced gps mode
    you may have to reinstall everything again making sure that MM is totally removed as well as compass & Xport2
    I had it splitting to like 6 ports... no problems
  1. Problems with MM Advanced Mode/SiRF
    By RoyN in forum Map Monkey
    Last Post: 04-24-2005, 12:49 PM
  2. MM keeps crashing?
    By miztahsparklez in forum Map Monkey
    Last Post: 03-09-2005, 02:40 AM
