Page 5 of 7 FirstFirst 1234567 LastLast
Results 41 to 50 of 64
Thread: Garo's Extra POI Plugin 1.0 beta 1
  1. #41
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    Quote Originally Posted by ccsnet
    Garo - do you have the format of the Destinator DAT file ? I want to use POI Edit with this but the guy who wrote it says he does not have the format to out put.
    I know worse case I can use Tomtom files but I would rather have Destinator types so I have the option of using say Freedrive.
    If its long and complicated can you give him a shout here - http://www.poiedit.com/contact.htm ?
    BIG Thanks
    Terran
    I don't have specific of the file, I just have some guidelines and then I proceeded with attempts... However, there are more than just one dat format (I found 5 different formats).
    I am coding an alternative program different from poiedit, look on my website, so I won't give around my code. However I'll implement the possibility to autoupdate poi files as soon as I finish GaroNav (I will release it in the next days, stay tuned).
  2. #42
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Quote Originally Posted by garo
    Cool just what I need... thats why I was playing with POI edit to DL what I need and update dynamically.
    Terran
  3. #43
    Sep 2005
    Does this only show up the POI's when looking in my favourites folder? They only show up there and not in the normal POI folder is that normal?
    Cheers,
    Richard
  4. #44
    May 2005
    Derbyshire, UK
    Quote Originally Posted by RichardB
    Cheers,
    Richard
    Yep, but lists them in order of distance from your current location.
    Old setup
    Epia M10k, Cubid 2699R case, 512MB, 40GB 3.5" drive
    New setup
    Optiplex 260SX (2.8GHz P4, 512MB, 30GB, DVD)
    Xenarc 700IDT, USB hub, 802.11g, bluetooth, P2140, P5V
  5. #45
    Maximum Bitrate P3rv3rt B3ar's Avatar
    Jul 2005
    Funland
    Theres bug in extraPOI
    it is supposed to work with .CSV .DAT files right? but it doesnt. Correct behavior can only be observed with .ov2 files.
    I needed to do tests with POI thats easy for human to input. So i typed CSV file by hand... however that didnt work in extraPOI like it was supposed to. So i convert hand written file with your POIconverter to .DAT, that didnt work either. But when i convert same original hand written file with your converter to .ov2 file extraPOI plugin works like it is supposed to!
    Problem is that .CSV .DAT file contained POIs appear correctly on favorites (even distance is counted like it should be) but when u look additional information from these favorites, u noticed that lat and lon values both appear to be zero, which also causes that these POIs can't appear on map or u can't ruote to them.
    Because of this goddamn bug... i lost quite a bit of time when pondering around it... so i would be really grateful if u could give me info about .DAT (destinator) POI format... I mean if u dont... ill find it out anyhow... u could just save bit of my time....
    BTW great software.
  6. #46
    May 2005
    Derbyshire, UK
    It works fine with .dat files from http://www.poihandler.com/
    Old setup
    New setup
  7. #47
    Jan 2005
    Milan, Italy
    Quote Originally Posted by P3rv3rt B3ar
    BTW great software.
    It should work but I will be glad to help you. Can you send me one of those CSV?
  8. #48
    Jul 2005
    Funland
    Quote Originally Posted by markbuts3
    Ok, im too lazy to registered the site u mentioned...
    But i did repeated test, this time not with file written by me, but .ov2 file downloaded from net (swedish gasoline stations). And if u feed it to garos extraPOI as it is (as .ov2 file) everything works fine, but if u before that use garos POIedit to convert it to .dat file... results are same as in my tests with my own file.
  9. #49
    Jan 2005
    Milan, Italy
    GaroNav 1.0
    As promised, I released my frontend!
    Go to the specific thread here:
    http://www.mp3car.com/vbulletin/other-cool-stuff/61450-garonav-1-0-beta-1-released-post644395.html
  10. #50
    Jul 2005
    Funland
    Hmmm looks cool.
    Have to give it a try.
    Any hope for CF look and feel skin?
  1. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 06:17 PM
  2. Replies: 33
    Last Post: 10-18-2005, 02:38 PM
  3. Replies: 4
    Last Post: 08-12-2005, 10:51 AM
  4. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-11-2005, 12:39 AM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 04:54 AM
