Page 6 of 7 FirstFirst 1234567 LastLast
Results 51 to 60 of 64
Thread: Garo's Extra POI Plugin 1.0 beta 1
  1. #51
    Variable Bitrate garo's Avatar
    Jan 2005
    Milan, Italy
    Quote Originally Posted by P3rv3rt B3ar
    Hmmm looks cool.
    Have to give it a try.
    Any hope for CF look and feel skin?
    I don't think I will create such I skin but if you or someone want to try... I will be glad to publish on the website
  2. #52
    Sep 2005
    I have a problem with this on my car pc but it works on my home pc
    When MM is starting up it throws an error that ends in 0000135 I think, only option is to press ok to terminate the plugin. Also when I press configure in the plugin section of MM config it doesnt pop another box up. What is going on here? I really want to get it working in the car
    Cheers,
    Richard
  3. #53
    Jan 2005
    Milan, Italy
    Quote Originally Posted by RichardB
    Cheers,
    Richard
    Install .net framework OR (better choice) use my GaroNav (check my signature).
  4. #54
    Sep 2005
    Where do I get .net from? I am already using a frontend I am used to now, but might give it a try at some point
  5. #55
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Microsoft / Windows Update...
    Terran
  6. #56
    Sep 2005
    Ok I downloaded the 1.1 .net framework and now the plugin works yay!
    Only problem is that when the plugin is turned on it makes my system run slow. When in MM if I press the next track button it changes but takes about 5 or more seconds to show it in the display box, it aso makes my audio menus in RR very very slow. Anyone else had this problem or could perhaps shed some light on the situation?
    cheers,
    Richard
  7. #57
    Jan 2005
    Milan, Italy
    cheers,
    Richard
    You may have too many pois. Or try to lower update speed. Or get rid of MM and download GaroNav
  8. #58
    Sep 2005
    Quote Originally Posted by garo
    Only put McDonalds, Cinemas and supermarkets on. Will have a look at the update speed, see if it makes a difference. May try GaroNav but would assume it should work the same in MM as GaroNav....
  9. #59
    Jan 2005
    Milan, Italy
    It is completely different because in GN I update pois just when I need it, so there's no slow down due to the plugin refresh.
  10. #60
    Constant Bitrate peijffertje's Avatar
    Nov 2005
    Netherlands
    bitmaps
    Hi,
    I got it to work and I get notified when I aproach POI's but what I dont get are the bitmaps on the map that correspond with the POI's.
    I emptied my database with cam's in MM so that I use the cams I import from Tomtom in Garo's plugin only, but the cam's from MM are still displayed on the map. Does that have something to do with it?
    I apreciate your help.
  1. Problems installing Girlfriend 1.0...
    By gospeed.racer in forum Off Topic
    Last Post: 10-18-2005, 05:17 PM
  2. Replies: 33
    Last Post: 10-18-2005, 01:38 PM
  3. Replies: 4
    Last Post: 08-12-2005, 09:51 AM
  4. RR 04-08-05 .. BETA Base Plugin ...
    By guino in forum Road Runner
    Last Post: 04-10-2005, 11:39 PM
  5. Blackwind's keypad plugin v2.0 beta released
    By Blackwind in forum Software & Software Development
    Last Post: 02-11-2001, 03:54 AM
