Ive tried using the provided CFD3 launcher application but this fails to work at all. It loads Map Monkey and you get a screen in CF that says Map Monkey is loading but the GPS window never embeds. The window becomes seperate and not embedded
I then tried just straight embedding mapmonkey.exe into CF and this properly embeds. Only problem here is that whenever you go navigate to a destination the OSK comes up but not the upper window allowing you to see the addresses and such.
Before I give up completely, anyone have any input?
