Results 1 to 9 of 9
Thread: Map Monkey Problems
    Sep 2005
    Map Monkey Problems
    Hey guys,
    I've been having real problems getting my Leadtek 9537 Bluetooth GPS adaptor running with Map Monkey 1.1.3 and Destinator 3. The device is connected via a Belkin Bluetooth USB adaptor. (And yes I've spent the last 3 hours searching through previous threads trying to find a solution )
    I'm using the device inside so I'm not expecting any satellite connectivity, but no matter what COM port I change the device to or what program I use to connect to my bluetooth device, nothing works. The device is picked up fine by windows and installs without a hitch, but for some reason I cant get ANY program to connect to it properly or recieve data. Whenever I try in MapMonkey using the advanced mode it says "GPS isnt found". When I try finding it under the GPS status, it also says not found but when i specify the port and baud rate, it says "comport busy".
    Can anyone give me any hints as to how to get this working properly, I'm getting a serious headache from fiddling with it for the last 5 hours.
    Any help much appreciated,
    Thanks.
    Variable Bitrate Mr.Fabio's Avatar
    Feb 2005
    Italy
    Try to use Hyper Terminal to test the connection, before MapMonkey or any other Gps Sw
    Fabio
    _______________________
    Travla C134
    Jetway J7F2WE 1Gb DDR2 - HD SATA 3.5" 80Gb + HD 2.5" 40Gb - Lilliput 7" TS - Holux GR-213 - Bluetooth - Belkin 802.11g WiFi - Silabs Radio - HTC Leo
    RoadRunner - PC Navigator 7.1 - FreeFone
    Sep 2005
    What should I use hyperterminal to do with my bluetooth device though?
    Feb 2005
    Italy
    I'm guessing the reason it's not working is due to the wrong Com port, wrong baud rate or protocol selected. Get SiRFDemo or some other GPS diagnostic like HyperTerminal app and see if that can connect.
    So you can see if you're receiving NMEA messages or SiRF (NMEA will be plain text, SiRF will be binary so you'll just get random chars)
    Fabio
    Travla C134
    Sep 2005
    Worth a try: disable Use Advanced GPS Mode (under Adv GPS in Configuration). I had the same problem and it fixed it.
    Sep 2005
    GTXP.DLL needed!
    Hello,
    my mapmonkey freezes afrer 5-20 seconds with a problem in a gtxp.dll
    can somebody tell me where can i download a different version of this file? The link, that was given in this forums is not working.
    Thanky You!
    Sep 2005
    Quote Originally Posted by {icebox425}
    The driver of gps emulate a com port ( try - control panel - system -ha
    rdware proprieties - & search this driver)
    Simply connect hyperterminal to com port emulate blutoth gps.
    Check the driver of gps ,or update this .
    bye bye
    marco
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    Quote Originally Posted by balatonair
    Hello,
    Thanky You!
    Where to download Fixed Gtxp.dll named Gtxp_beta.dll
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Sep 2005
    please someone help me.i have post a tread before but noone reply.
    i doubleclick mapmonkey's icon to open.....it runs.....busy mouse icon appears....and then nothing.map monkey not opening.
    by pressing ctrl+alt+del and task manager showing up i see that map monkey appears as not responing program.
    i have made a format to my pc but nothing changes.
    HEEEEEEEEEEEEEEEEELP
  1. CF 2 Beta + Map Monkey 1.3
    By stevieg in forum Centrafuse
    Last Post: 08-27-2005, 11:42 AM
  2. Replies: 4
    Last Post: 08-05-2005, 03:43 PM
  3. Copying Map Monkey to new laptop
    By UHF in forum Map Monkey
    Last Post: 07-12-2005, 05:10 AM
  4. Map update problems
    By Dunk in forum FD Bugs
    Last Post: 07-05-2005, 03:30 AM
  5. Anyone using Map Monkey 1.1.3 with Deluo USB GPS?
    By Chita79 in forum Map Monkey
    Last Post: 02-04-2005, 01:06 AM
