I assume you mean you've edited the Hotkeys.ini to setup a hotkey for using winamp?
If so, can you post the contents of the ini file?
Someone can help me ?
I use MM but hotkey for winamp seems not work.... is this a bug ?
when i map MM control to winamp and use skin button instead function....
but i need to use hotkey and not skin button
thanks
Destinator 3 For PC! - http://www.map-monkey.co.uk/
yes I used the ini file with this settings
Hotkey29=Local,FE_WINAMP_NEXT,{CTRL},N
I tryed some other combination key and i'm sure that the hotkey number is not used in any other hotkeys function.
the strange things is that de button in the skin funcion....
I have the last version of MM with all hotfixes
thanks a lot
Hmmm...
Try making it a global hotkey?
Hotkey29=Global,FE_WINAMP_NEXT,{CTRL},N
didn't work also using Global hotkey .... :-(
Ninja Monkey, I've tried everithing but winamp hotkey still not work properly there is a solution ?
