Results 1 to 8 of 8
Thread: Bluetooth Gps Map Monkey
    Oct 2005
    THESSALONIKI GREECE
    I just bought a BT GPS receiver (Fortuna Slim - Sirf star III chipset). I tried to set it up and work with map monkey and it is not possible.
    My Pc has not BT intergrated so I bought a BT usb adaptor (Level one the brand - the installation programm says Toshiba). My problem is that the Level one adaptor creates virtual com ports (BT gps receiver is assigned to com 41). I checked with hyperterminal there is a connection. I am not able to tell mapmonkey to use com 41. I could use a little help.
    By the way great job with map monkey. I always wondered if such a programm exhisted.
    Elsewhere
    It's likely that with some clever reconfiguration, you can get a lower COM port assigned to the bluetooth connection that MapMonkey should like better than COM41.
    How about the Wiki?
    Oct 2005
    THESSALONIKI GREECE
    Unfortunatelly it seems 40 is the lowest it can go
    Variable Bitrate ildena's Avatar
    Dec 2004
    Italy
    Yo have to delete wrong ports.
    Search this forum about "remove hidden periphrals" or similar
    See my car and donate for spinning logos at www.ildena.it/carpc
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    If you're using Advanced GPS, simply open the Settings.ini inside the map monkey folder and change the COMPort entry to 41.
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Oct 2005
    THESSALONIKI GREECE
    Thank you all for your replies. I reinstalled the BT GPS and this time I followed the custom settings and was able to install it at com port 4. Now is woking perfect. very happy with the fortuna as well very small - long life of battery.
    Constant Bitrate ThEScReW's Avatar
    Nov 2004
    Kortrijk/Belgium
    It still doesn't work for me GPS works fine : i hit search gps, mapmonkey say's : gps found on com 4 with 57000, it sets the current location and then it tells me gps not found.
    If i set the port myself it tells me : com port is in use...
  1. RELEASE: Map Monkey v1.1.348 (Hotfix)
    By Ninja Monkey in forum Map Monkey
    Last Post: 04-06-2007, 01:58 PM
  2. Replies: 91
    Last Post: 11-07-2006, 05:47 PM
  3. On screen delay/stuttering with Map Monkey
    By Anees in forum Map Monkey
    Last Post: 06-22-2005, 05:22 PM
  4. Anyone using Map Monkey 1.1.3 with Deluo USB GPS?
    By Chita79 in forum Map Monkey
    Last Post: 02-04-2005, 02:06 AM
