1) Type can be anything at all, when the entry is is detected it will show an onscreen alert of "<TYPE> detected" and if there is a sound file called Warning1_<TYPE>.wav it will play it (If not it will just play the default)
2) Name is simply a unique description field that is used when adding the camera to destinators favorites.
3) Speed works for all types, if it is anything other than zero the value will be shown on the onscreen alert. Logic mode also uses this value to determine whether to play a sound or not (Logic mode means a sound will only be played if you are actually speeding)
4) When you add a camera using Map Monkey, it is added with a Type of "Manual"
LinkBack URL
About LinkBacks
