Can you tell me the WCE.TXT info from the UK_Ireland PN map ?Quote:
Originally Posted by rustyboxx
I'd like to see if I have the latest maps.
PM me if necessary...........
Wizz
Printable View
Wizz
Hi,
guys could you please cut some maps for me.
I've tried to all you've written but it always crashes.
I could send you archive with my map (3 Mb)
I don't know what happened but the last Destinator 6 Map (Isreal) is working properly.
I didn’t change anything. Someone can tell me what happened to the last ver of map?
Any one has cut or run the greek map in MM...Pn map i mean.!!
Am i missing something here???
I cant get the UK_Ireland Map to work.
So here is what im doing:
Unzip the folder to a folder called PN_UK in c:\Destinator Apps\Destinator
Copy over the WCE.txt file aswell to the same folder
This gives me the following files in my new folder:
- Default.IDM
- MapStreetTypes.TXT
- WCE.TXT
- WCE_A.cov
- WCE_A.map
- WCE_A.poi
- WCE_A.tab
- WCE_A.tmc
- WCE_A.trl
- WCE_A.dat
- WCE_b1.dat
- WCE_B2.dat
Here is were i get a biit confused...
Because in post 7 the guy deleted WCE_a.dat and WCE_b.dat but i have B1 and b2.dat.
Can some one describe the exact steps for doing the UK map.
Cheers folks
Ive just tried doing the following from this thread:
http://www.mp3car.com/vbulletin/centrafuse/76143-destinator-version-in-cf-1-7-a.html
And when i open up MM and go to change the map for this new on i get an error message sayingQuote:
Originally Posted by Cirion
"There were errors in new map data! We are returning to previous map..."
ANy help is much appreciated guys.
Ken
plz help i have also tryed all that but the same problem/error, and it says that my map is't registered. why..? the map im trying is a scandinavia map.. plz heeeeeeeeeeeeeeeeeelp:nutz: :confused:
Guys I have tried cutting a map (Benelux) several times but it still won't navigate. I can see the map and it works fine but when I try to navigate somewhere it just ignores me.
I deleted the WCE_bx.dat files as described, do you know perhaps what is wrong?
i've also tried to cut maps, no chance. i use now the hole maps and it's working:
- Extract map from ZIP file to x:\DestinatorApps\Destinator\MapName
- Delete WCE_b1.dat and WCE_b2.dat
- Copy the WCE.TXT for the map from the CD and insert in the same folder.
