Page 5 of 5 FirstFirst 12345
Results 41 to 49 of 49
Thread: How to insert the Dest. PN maps in Dest. 3?
  1. #41
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by rustyboxx
    I'll have a go a cutting different maps and see if they work on my system. Will let you know how I get on.
    Can you tell me the WCE.TXT info from the UK_Ireland PN map ?
    I'd like to see if I have the latest maps.
    PM me if necessary...........
    Wizz
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
  2. #42
    Feb 2006
    Hi,
    guys could you please cut some maps for me.
    I've tried to all you've written but it always crashes.
    I could send you archive with my map (3 Mb)
  3. #43
    Mar 2006
    I don't know what happened but the last Destinator 6 Map (Isreal) is working properly.
    I didnít change anything. Someone can tell me what happened to the last ver of map?
  4. #44
    Jun 2006
    Any one has cut or run the greek map in MM...Pn map i mean.!!
  5. #45
    Constant Bitrate KennyKen's Avatar
    England
    Am i missing something here???
    I cant get the UK_Ireland Map to work.
    So here is what im doing:
    Unzip the folder to a folder called PN_UK in c:\Destinator Apps\Destinator
    Copy over the WCE.txt file aswell to the same folder
    This gives me the following files in my new folder:
    • Default.IDM
    • MapStreetTypes.TXT
    • WCE.TXT
    • WCE_A.cov
    • WCE_A.map
    • WCE_A.poi
    • WCE_A.tab
    • WCE_A.tmc
    • WCE_A.trl
    • WCE_A.dat
    • WCE_b1.dat
    • WCE_B2.dat
    Here is were i get a biit confused...
    Because in post 7 the guy deleted WCE_a.dat and WCE_b.dat but i have B1 and b2.dat.
    Can some one describe the exact steps for doing the UK map.
    Cheers folks
    Prepping for Trax in september
    Re-Building the whole CarPC to upgrade all the software
    Whole new boot build and moulding my screen into the dash...Again
  6. #46
    England
    Ive just tried doing the following from this thread:
    Destinator Version in CF 1.7?
    Quote Originally Posted by Cirion
    PN maps works with CF1.6 but they have to be modified.
    This is what you have to do:
    1. Install a map you want.
    2. Delete WCE_b1.dat and WCE_b2.dat from that folder
    3. Copy in the WCE.TXT for the map from the CD and insert in the same folder.
    4. Open the edited map in MapMonkey mapcutter.
    5. Cut the map, does not have to be much, just cut something.
    6. Save the map.
    Now the map is in D3 readable form and works in MM, FD and CF
    And when i open up MM and go to change the map for this new on i get an error message saying
    "There were errors in new map data! We are returning to previous map..."
    ANy help is much appreciated guys.
    Ken
  7. #47
    Feb 2006
    plz help i have also tryed all that but the same problem/error, and it says that my map is't registered. why..? the map im trying is a scandinavia map.. plz heeeeeeeeeeeeeeeeeelp
  8. #48
    Jul 2006
    Guys I have tried cutting a map (Benelux) several times but it still won't navigate. I can see the map and it works fine but when I try to navigate somewhere it just ignores me.
    I deleted the WCE_bx.dat files as described, do you know perhaps what is wrong?
  9. #49
    Newbie ReDiculum's Avatar
    Apr 2005
    Zurich / Switzerland
    i've also tried to cut maps, no chance. i use now the hole maps and it's working:
    - Extract map from ZIP file to x:\DestinatorApps\Destinator\MapName
    - Delete WCE_b1.dat and WCE_b2.dat
    - Copy the WCE.TXT for the map from the CD and insert in the same folder.
  1. Replies: 0
    Last Post: 11-04-2005, 08:39 AM
  2. maps of destinator PN ( version 5 ? )
    By illo41100 in forum Map Monkey
    Last Post: 09-18-2005, 11:47 AM
  3. Adding maps ??
    By cnfusion in forum Map Monkey
    Last Post: 07-15-2005, 07:43 PM
  4. Can i use Maps of Destinator PN?
    By egon223 in forum Map Monkey
    Last Post: 06-07-2005, 02:47 PM
  5. TRADE? 20GB Notebook driver for Dest 3 maps
    By Bax350z in forum Map Monkey
    Last Post: 05-28-2005, 02:21 AM
