Ok first of all you need to put MM launcher inside the MM main folder, then open FP.ini and edit the GPS MM path to point that launcher,finally go to setting 2 and select MM in GPS.
About the maps you have to open MM and hit the button "switch maps" then if you descompress your maps in the right folder you will see the name of you state there.
Thanatos.
LinkBack URL
About LinkBacks
