Results 1 to 4 of 4
Thread: MapMonkey won't recognize COM3
    Sep 2005
    Pomona, CA
    I have a BU-353 set on COM3 and MapMonkey won't recognize that port at all, only COM2 and COM1, which are actual COM ports and not a virtual one like the one made with the drivers for the BU-353. Is there something I'm missing? The software that came with the BU-353 detects the COM port fine...
    Carputer Progress:
    Re-do fabrication of screen [DONE]
    Add mini-USB and micro-USB power from M2-ATX [DONE]
    Teardown PC [100%]
    Add HDMI > VGA converter [0%]
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    If you turn Advanced GPS mode on in map monkey configuration you should be able to select your COM port there instead
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Sep 2005
    Pomona, CA
    I've looked and looked and cannot find where the advanced GPS mode is. I've tried everything I can and MapMonkey still cannot connect to my GPS. It can find it fine, just can't set the GPS. Is there any answer?
    Carputer Progress:
    Teardown PC [100%]
    Aug 2003
    Warrington, UK
    In your start menu there should be a "Map Monkey - Configuration" shortcut
  1. Replies: 4
    Last Post: 07-19-2006, 07:57 AM
  2. Replies: 2
    Last Post: 10-28-2005, 10:16 AM
  3. FrodoPlayer and MapMonkey
    By Ti-ejtsch in forum FrodoPlayer
    Last Post: 05-19-2005, 06:24 AM
  4. In my opinion about MapMonkey
    By vol in forum Map Monkey
    Last Post: 04-12-2005, 06:15 AM
  5. Mapmonkey Intergration into MediaCar
    By ryan-neil in forum MediaCar
    Last Post: 04-08-2005, 03:28 AM
