Results 1 to 4 of 4
Thread: Voice routing directions
    Jan 2006
    Dublin, Ireland
    Hi all
    Is it possible to modify the distance before which the first routing instruction is gien. It currently gives it at 500 metres which for me is a bit too soon and I would like to change it to about 200metres. Is there an ini file which I can set it.
    Also, when creating a route, and if I select POI, it limits to 80km. If I select Whole Map, you then have to exit from this screen but when I go back in to create the route and use POI, it is still set to 80km so it is not saving the change. Is there an ini file which I can set it to whole map
    Cormac
    Map Monkey Creator Ninja Monkey's Avatar
    Aug 2003
    Warrington, UK
    you need to press enter (either on keyboard or OSK) after changing the POI options for it to take effect, simply closing the window will ignore it.
    As for the first distance - I think the best you can do is just disable the 500m voice by opening up C:\destinatorApps\Destinator\Common\Interface\Voic e\<Voice Skin>\DestinatorVoiceManeuvers.inf
    Comment out (prefix with //) or delete any lines that reference "SECOND_DISTANCE". I've not tested this so it might not work
    Destinator 3 For PC! - http://www.map-monkey.co.uk/
    Nov 2004
    St Louis
    Quote Originally Posted by championc
    Hi all
    If you open the MM Config and go to advanced GPS you'll find what you want to change abot 3/4 of the way down the page: 1st warning, 2nd warning.
    Hit OK and it will save those settings and open up the main program. Done.
    Jan 2006
    Dublin, Ireland
    Hi all,
    I modified the skin DestinatorVoiceManeuvers.inf and it worked a treat.
    Can anyone think of a way of resetting the default POI range from 80km to whole map?
    C
  1. Has Mappoint always had voice directions?
    By Mattkins99 in forum Road Runner
    Last Post: 02-15-2006, 07:32 AM
  2. Voice directions with MapPoint
    By skippy76 in forum RR Bug Tracker
    Last Post: 10-06-2005, 11:08 AM
  3. "ding" insted of voice directions
    By jims_trepid_96 in forum GPS
    Last Post: 12-19-2004, 09:15 AM
  4. Delorme Street Atlas 05 quick review
    By cash_Money in forum GPS
    Last Post: 12-13-2004, 08:31 PM
  5. Replies: 2
    Last Post: 03-24-2004, 05:54 AM
