Anyone?
I have installed this on 2 PCs and both have the same issue. Both were updated to the latest MM version and hotfix.
Surely someone must have the same problem at least?
LLOYDY
I have installed MM on two PCs now and both have the same problem. When entering information using the OSK it won't let me type whole words. Only single letters will come up. For e.g., if I want to type "LONDON", I can press the "L", but when I press the "O", the "L" is replaced with it instead of the input becoming "LO". This happens all the time, with whatever I want to put in, with all skins.
Can someone please help me?! It's driving me mad!
LLOYDY
Anyone?
LLOYDY
I didn't understend...
When u type LONDON and u press L u get L...
When u press O what do u get? "L" or "O"?
BMW E36 Project [ =======§== ]
Hardware:
Lilliput 7" Touchscreen - Epia M-10000 - HQCT 1.0 FM Radio - 2.5" 80Gb - USB GPS
Software:
FrodoPlayer 1.10 & MapMonkey with FriBruMet Skins by Frigor.
I'm not using MM (Destinator) now anyway. iGuidance is much better.
I was having a problem where you cannot type a word. Just single letters. The next letter you press would simply overwrite the last. If you pressed "L" an "L" would display. If you then pressed "O" an "O" would replace the "L" instead of the display showing "LO".
LLOYDY
ah, ok...
Hardware:
Software:
i have the same problem, but i have noticed this:
if I run MM alone, all went ok, no problem with writing;
if I run MM under RoarRunner i have that error.
Software [|||||||||-]
My Own RR Skin [|||-------]
8" LCD TS 1024 x 768 - Epia M10000 - M2 ATX - 512 Mb - 40 Gb - Creative Sound Blaster Audigy 2 ZS Video Editor - Sitecom BT Dongle - GPS BT-77
RoadRunner - Destinator 6 - Waiting for RRMobile
Yes this was the same for me aswell.
OK Standalone, NOT OK in RR
LLOYDY
I don't know how, but the problem is solver by itself.....now run perfectly under RR....
Problem is RR "Gesture" feature!
Available solution:
Please set gestures feature to off!
RR.INI -> usegestures=false
Renault Megane II Berline 1.5 dCI Dynamique Plus 2004
Epia SP13000, HDD 40 Gb, CarTFT MM400 7" touchscreen, SB Audigy 2 (PCI), Terratec Cinergy 600 TV/FM tuner, M1 ATX
Gigabyte USB BT dongle, X-Micro Wlan USB stick
Globalstar BR-353 USB GPS
This problem was around waaay before the gestures in RR. So not neccessarily...
LLOYDY
