Results 1 to 3 of 3
Thread: Install MapMonkey in another location.
    Jun 2005
    This may have been mentioned before but after a I could't find anything.
    I wish to have Destinator and MapMonkey on my d: drive as my c: is relitively small. By moving the files over and attempting to run MapMonkey I get an error.
    I noticed in the MapMonkey installer there is no option to change the installation directory. Can this be done or is it hard coded to work from c:\Destinator Apps\MapMonkey?
    Thanks.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    the Destinator SDK is limited to run on the C: drive and in that particular location.
    the only way to change that would be to hack the DLL, but you might get some unwanted results.
    FLAC strohj's Avatar
    Aug 2004
    Pearland
    http://support.microsoft.com/default...307889&sd=tech
    here you go... basically you need to map c:\destinatorapps to point to a folder on your D drive...
  1. In my opinion about MapMonkey
    By vol in forum Map Monkey
    Last Post: 04-12-2005, 05:15 AM
  2. Mapmonkey Intergration into MediaCar
    By ryan-neil in forum MediaCar
    Last Post: 04-08-2005, 02:28 AM
  3. install mapmonkey other then C
    By BOND007BE in forum Map Monkey
    Last Post: 02-25-2005, 08:21 AM
  4. Please help install a Front End
    By Zebelkhan in forum Newbie
    Last Post: 01-31-2005, 05:40 PM
  5. Location of application floating bar resets to 0
    By Izik in forum Media Engine
    Last Post: 03-14-2004, 11:25 AM
