Results 1 to 4 of 4
Thread: Map monkey just closes - wrong maps
    Jan 2004
    Why can’t I use maps from X-Road3, its basically the same files as the downloaded maps, from that German site.
    I can open the new maps with the map cutter, and the maps are from destinator, when I try them in Map Monkey, Map Monkey just closes with no fault or anything??
    The old map was named
    Skandinavia:
    Denmark, Finland, Norway, Sweden
    Version 2003.2.2204 - map of TeleAtlas. HLG4, Toll roads, MLC, ML POI v2,Signed map
    The new is
    Skandinavia:
    Version 2005.R2.3622 - map of TeleAtlas. HLG3, Toll roads, Rural, WES2. Signed map
    Jan 2004
    Anyone?
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Is it a PN map?
    if so you need to delete some of the files and then open and save itt in mapcutter.
    do a search for how to get PN maps to work with mapmonkey.
    Jan 2004
    Quote Originally Posted by Enforcer
    Is it a PN map?
    How can i see if it is a PN map?
    Weird, if i cut the map down to 1mb, then it loads up, and i can make a map, but if I cut it down to ex. 26mb i just crashes.
    I tried to search for the PN solution, but if i del. the files it just says "wrong map, going back to last map"
  1. Map Monkey Update
    By Ninja Monkey in forum Map Monkey
    Last Post: 05-12-2006, 01:25 PM
  2. CF 2 Beta + Map Monkey 1.3
    By stevieg in forum Centrafuse
    Last Post: 08-27-2005, 12:42 PM
  3. Copying Map Monkey to new laptop
    By UHF in forum Map Monkey
    Last Post: 07-12-2005, 06:10 AM
  4. is the gps wrong or is the map
    By beaverpants in forum GPS
    Last Post: 05-09-2004, 10:51 PM
