come on guys, gimme a hint at least here.....anyone ?
I have an application that sends keyboard presses to the focused application, it works for RoadRunner, but if i map the same keys in MM it does nothing, it works if i press the keys on the actual keyboard.....what am i doing wrong ?
I am starting MM outside of RR and inside RR, but its the same problem.
I have defined this in hotkeys.ini :
Hotkey01=Global,FE_MENU_OPEN,{},F3
Hotkey18=Local,FE_MENU_ITEM_ROUTETO_HISTORY,{},F4
Hotkey22=Local,FE_NAVMODE_TOGGLE,{},F5
Hotkey23=Local,FE_ROUTEMODE_TOGGLE,{},F6
And i am using this syntax in vb :
SendKeys ("{F3}")
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
