I am running XP Pro and need to know if a DeLorme USB Earthmate GPS LT-20 will Work With the Map Monkey (MM). If so, how do I configure MM and my computer?
Yes it will, you need to install usb to serial driver (available for download at DeLorme) http://www.delorme.com/support/suppo...te.aspx?id=217
Marek
DeLorme does not use the NMEA protocol. You need a driver that converts it.
Here you go.
http://www.delorme.com/support/suppo...te.aspx?id=319
