I think your MM path may be wrong in RRConfig. The MapMonkey Path should point to MapMonkey.exe. The GPS Path should point to MapMonkeyLauncher.exe. Also make sure the GPS Window Name is set to MapMonkey.Originally Posted by nbinder
Have you used MapMonkey Config to set up MM...and does it run on it's own OK, independent of Road Runner. If the answer is yes, it is probably the wrong paths in RRConfig.
Wizz
LinkBack URL
About LinkBacks
