Results 1 to 3 of 3
Thread: Map Cutter and PN 2005 maps...don't work??
    FLAC mauri's Avatar
    Jan 2004
    Arrow Map Cutter and PN 2005 maps...don't work??
    I have the Q3 2005 PN maps for try...
    Well, Map Cutter of MM, dont' work ok for remake the maps of D3 compatible.
    In the 2005 PN maps,the file WCE_A.DAT not it's make in the same format of 2004 PN maps.
    If anyone use the same procedure for create new maps type 2004 PN maps, but use 2005 PN maps, Map Cutter of MM crash.
    With the Consolle original of PM,if you cut the maps, this don't working with D3 SDK based frontend....
    EDIT:I know all for make the PN maps with MapCutter for work with MM, or FD o GN , but the problem it's this new format of WCE_A.DAT 2005 to PN maps!
    If anyone have remake one maps to PN 2005 with MapCutter by MM, please, write fo all the procedure!
    Mauri
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    Doesn't work with D6 maps either
    Car : Ford Focus Zetec S 1800cc
    Carpc :Galaxy GT-P1000 Original 7in Tab
    Mounted in "On Dash" Custom Install
    FLAC mauri's Avatar
    Jan 2004
    Quote Originally Posted by wizz
    The same, identical based maps and problem....If Ninja know the code of Map Cutter, I hope fix this...
    Mauri
