Results 1 to 5 of 5
Thread: pocketgpsworld speed camera?
    Oct 2002
    UK
    Hey all,
    Just downloaded the pocketgpsworld speed camera db in 1 complete csv file
    Trying to import it to Map Monkey but just says 'Invalid Format'.. the format is:
    GATSO:548@30 Pocket GPS World (c) 2006 -1.90085 53.26345
    GATSO:549@30 Pocket GPS World (c) 2006 -2.13723 53.3888
    Any ideas? need this doin asap
    Volvo C70 - Installation in progress *gulp*
    Raw Wave
    Jun 2004
    On the beach
    It will be the Pocketgpsworld in the middle but I don't know the official layout for the MM files. try taking out the copyright stuff and see if that helps.
    Oct 2002
    UK
    Quote Originally Posted by Gobby
    Cheers for the reply!
    Thats what im trying to figure out (the official layout) I think it is:
    Type,Longitude,Latitude,Name,Speed
    "MOBILE","-1.41791","52.32594","1","0"
    As thats one of the lines in the mapmonkey download section... im struggling in converting the following to work though:
    GATSO:1@40,-2.17788,50.68304,blank,blank
    May 2006
    United Arab Emirates
    Have a look at http://www.gpsbabel.org/capabilities.html
    Plenty of conversion options there!
    Jun 2006
    Hi Corsamel,
    that format seems different than the one I know of. I was under the impression pocketGPS had comma-sep data, not tab-sep. Well, here is a way to change it using excel
    first replace all tabs with comma in any editor.
    then replace all @ with comma.
    finally replace all : with comma.
    finally import the file in excel; you should have several columns, where
    - 1st column is MM Type
    - 2nd column can be used as MM Name
    - 3rd column is MM Speed
    - 4th column is not needed
    - 5th column is longitude
    - 6th column is latitude
    now delete 4th column from excel; and move the rest around to fit MM specification.. finally save it again as CSV.
    import the file in excel; I believe you can choose the delimeter; choose Tab character (or you can replace all tabs with comma in most editors)
    once imported
    Quote Originally Posted by corsamel
    Hey all,
  1. Replies: 2
    Last Post: 08-31-2005, 06:01 PM
  2. GATSO Hunter v0.1 (Beta) - Standalone speed camera detection
    By Engram in forum Software & Software Development
    Last Post: 03-02-2005, 05:02 AM
  3. Speed / Red Light Camera
    By Skorpion in forum Map Monkey
    Last Post: 02-22-2005, 01:44 PM
  4. Speed camera detection software on laptop
    By rickyaswell in forum LCD/Display
    Last Post: 08-26-2004, 07:13 AM
  5. Replies: 11
    Last Post: 04-12-2004, 05:10 AM
