Results 1 to 10 of 11
Thread: Map Monkey and destinator 6
    Dec 2005
    France
    Hi,
    Destinator is selling new maps (destinator 6). Are these maps supported by map monkey?
    _
    Mar 2004
    Little Elm, Texas
    where the heck is this Destinator 6 stuff coming from?
    I'm guessing it's only in Europe?
    Jan Bennett
    Variable Bitrate marazi's Avatar
    Dec 2005
    Skien, Norway
    the new destinator 6 maps does not work with the current version of MM
    ive tryed mapcuter etc but no luck, guess we have to wait for an update of MM
    Dec 2005
    France
    Unhappy Well, let's wait !
    destinator 6 is here : http://www.destinatortechnologies.ne...ucts/products/
    Bad luck.... my street doesn't exist on the map I use. I have to wait for a new MM release.
    Dec 2005
    Skien, Norway
    yup, guess we have to wait for an updated version of MM
    Newbie ReDiculum's Avatar
    Apr 2005
    Zurich / Switzerland
    jap, my MM crashes with an exeption if I select a new, cutted map from destinator 6 and I cannot restart MM again (always get exeption). the problem must be in destinator.ini because by restoring a backuped destinator.ini file that includes the original UK map, MM works again.
    would be cool if this will be fixed soon because my trip to spain is coming closer
    EDIT: same problem if I cut a D6 map with map cutter from MM
    Dec 2004
    The Netherlands
    Don't know if it would work, but you can try to make destinator.ini readonly.
    Apr 2005
    no, didn't work. write errors. anyway. destinator PN maps are working fine.
    Jul 2006
    Have anybody read about a new release of mm?
    There must be something behind the wall!?
    Low Bitrate BioHazard's Avatar
    May 2006
    Luxembourg, EU
    Quote Originally Posted by Yahn
    Uhmmm, do you need a navi to get home??
    Project BioHazardous Material || BioHazard . LU
    ████████████████░░░░ CAR
    ████████████░░░░░░░░ LAPTOP
    █████████████░░░░░░░ FRONT-END SKIN
    ██████████████░░░░░░ PERIPHERALS
    ░░░░░░░░░░░░░░░░░░░░ INTEGRATION
