Results 1 to 10 of 12
Thread: MM con Destinator 6
    Newbie Attilio's Avatar
    Aug 2006
    Unhappy MM con Destinator 6
    Sto provando in ttti i modi di far leggere le mappe di destinator 5 a map monkey ma non riesco vorrei sapere se qualcuno di voi è riuscito....
    Sarebbe bello se potessimo far girare proprio il nuovi D5 con anche tutta la sua grafica.
    La cosa più importante è però avere le mappe aggiornate.Sapete percaso se ci sono altre mappe aggiornate e sicuramente funzionanti su MM?
    Se in ita non va bene riposterò tradotto
    FLAC ShawJohn's Avatar
    Aug 2004
    On the edge!
    English please! Mauri manages so do many others
    Aug 2006
    I am trying in any case to make to read the maps of destinator 5 map monkey but I do not succeed I would want to know if someone of you is successful…. It would be beautiful if we could make to turn just new the D5 with also all its diagram. The thing more important is but to have the modernized maps. there are other modernized maps and sure working on MM?
    Aug 2004
    On the edge!
    Map Monkey, Freedrive, and GaroNav will ONLY work with Dest 3.x, and Dest. SP Maps.
    AFAIK no one has successfully managed to get ND or PN maps working with the older SDK/DLL combo. You might get it to display, but routing will not work!
    Use the button when ever possible, this save everyone time and also forum space
    Welcome to MP3Car Attilio
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Bit harsh.
    Bear in mind English is obviously not this guys first language. It can be bit of a bugger getting the right search words as it is, but when you are not using your first language it must be a whole lot more difficult.
    Chill out John.
    Aug 2004
    On the edge!
    fair point
    Edited!
    Aug 2006
    Thanks I will try using the Sp maps
    Newbie ReDiculum's Avatar
    Apr 2005
    Zurich / Switzerland
    Quote Originally Posted by ShawJohn View Post
    for some strange reasons only the iberia PN map is working with routing. france and alps didn't. don't know what i've done. the problem seems to be in the WCE_b1.dat and WCE_b2.dat files. these are the routing files and MM crashes with this files included in the region directory.
    Constant Bitrate xpluis's Avatar
    Sep 2006
    Mexico City
    I put destinator 5 map of mexico and work fine in destinator 3 with mapmonkey and freedrive.
  1. RR Menu to emulate MM Menu button
    By GizmoQ in forum Map Monkey
    Last Post: 09-05-2006, 03:02 PM
  2. Allowing MM to remain on top?
    By Ashthos in forum Road Runner
    Last Post: 10-31-2005, 08:40 PM
  3. Problems with MM Advanced Mode/SiRF
    By RoyN in forum Map Monkey
    Last Post: 04-24-2005, 12:49 PM
  4. Creating RR Skin For MM
    By studly_steve007 in forum Map Monkey
    Last Post: 04-14-2005, 02:20 PM
  5. SENDKEY & MM Embedding
    By ruairi in forum Road Runner
    Last Post: 04-04-2005, 05:36 PM
