Results 1 to 10 of 10
Thread: Fixed
    Deactivated Diewlay Lowmo's Avatar
    Aug 2004
    Fixed
    Thanks for looking
    Maximum Bitrate wizz's Avatar
    Nov 2004
    Leicestershire UK
    I believe it's in a file called HISTORY.DAT in:-
    (Default) C:\DestinatorApps\Destinator\Common\Favorites
    Don't know what will happen if you delete it......so try moving it.
    Perhaps MM will renew it.
    Wizz
    EDIT: Just tried deleting this and the info is still displayed....perhaps you can't clear it ??
    Car : Ford Focus Zetec 1.6
    Carpc :Lin-ITX Plus 7" touchscreen/Toad 8" roof screen
    Morex 3688 case/M2-ATX PSU/Commell V-672 P4 3.2Ghz/1024DDR2/40GB 2.5" SATA HDD/Sony DVD/CDRW
    BU303 GPS/Mercury 11b WiFi/Parking Sensors
    Colour I/R Reversing Camera
    Nov 2004
    UK
    If you select the menu option to navigate to favourites (or "favorites" if you prefer ), highlight each destination item, then the red "Tools" button at the top - one of the options is edit, or you can delete it.
    You will need to do this for each item in your favourites list - I don't know a way to do them all at the same time.
    The same thing works for removing items from the history list, or any of the other lists (eg "Roadworks")
    Hope this is of some use
    Ian
    Nov 2004
    UK
    Oh yeah - I was looking under the "History" category of the favourites menu. You can delete these, but it doesn't remove them from the navigate to history list.
    Sorry, I'm no help at all
    Ian
    Aug 2004
    Mar 2004
    Stockholm, Sweden
    I think you have to delete PREVIOUS.DAT in the current selected map folder.
    Confusion Master
    Enforcer's Avatar
    Sep 2003
    Have you been going to well known red light districts?
    or are you trying to wipe the addresses of some old girlfriends?
    Aug 2004
    Bump
    Nov 2004
    Leicestershire UK
    Quote Originally Posted by Diewlay Lowmo View Post
    Can anyone please confirm.
    Confirmed Try it !!
    If your really scared about doing ANYTHING.......just move it !
    FreeDrive Creator CdRsKuLL's Avatar
    Feb 2004
    Manchester
    this is stored in the current MAP folder your using. I think its called PREVIOUS.dat or something.. just delete that.. or stop visiting them brothels !
    CdR
  1. RELEASE: Map Monkey v1.1.3
    By Ninja Monkey in forum Map Monkey
    Last Post: 02-12-2009, 11:27 AM
  2. Replies: 106
    Last Post: 10-20-2008, 10:09 AM
  3. Map monkey just closes - wrong maps
    By clemen in forum Map Monkey
    Last Post: 03-02-2006, 05:03 PM
  4. Few Questions About Map Monkey and Destinator
    By Yevgeny in forum Map Monkey
    Last Post: 08-10-2005, 06:00 PM
