Page 10 of 14 FirstFirst 1234567891011121314 LastLast
Results 91 to 100 of 132
Thread: PC Navigator 7 - Europe
  1. #91
    Maximum Bitrate jonessc's Avatar
    Nov 2006
    Wales, UK
    Now im starting to get into PCN7, how the hell do you use the street no?
    I put a post code in, but get no screen to enter a house no in, unless i enter the full address manually?
    Anyone think the voice is annoying? im thinking of replacing them with a voice pack less frustrating wot u guys think?
    CarPuter Progress:
    Planning:-----> [||||||||||] 100%
    Hardware Buying:-> [||||||||||] 100%
    Software:-----> [||||||||||] 100%
    Installing:-----> [||||||||||] 100%
    Current Project= Making skins in photoshop...
  2. #92
    Mar 2007
    manchester, UK
    i've never noticed it didn't do that. i suppose because you are never more than 200yds away from your destination with a postcode, they thought you wouldn't need to put in a house number.
  3. #93
    Nov 2006
    Wales, UK
    Quote Originally Posted by wilgartw View Post
    Thats true but some postcodes without the house no, you'd be looking for ages in some areas esp if theres different turn in's (and where its to dark to see the house no's) to get to the house no like some of the areas i been recently, always used tom tom which would allow this, does make a difference, there must be something im missing in the settings some where
    CarPuter Progress:
  4. #94
    Jun 2006
    London
    Ok guys, im having a blonde moment...in my main skin i have the following:
    B03,0,315,239,87,"LOAD;GPS.skin;!BarneyMainWndCls! Navigator;C:\Progra~1\Navigator7\PC_Navigator\PC_N avigator.EXE --window_border=no --window_position=0,0,800,529;!BarneyMainWndCls!Navi gator;Navigator",""
    this will load an empty skin only. if i remove the parameters ( --window_border=no --window_position=0,0,800,529) , PCNav runs ok but its not right as the window is not resized properly. Am i doing something wrong with the way im righting the parameters? Any help would be appreciated. Thank you
  5. #95
    Oct 2007
    Setting "Navigate to" from a external program
    Hi Pc-Navigator Thread
    I look for a simpel API, to control the PcNavigator7 software.
    I need to control Pc-Navigator to do the following:
    1) start "Show map only"
    2) Start "Navigate to adress"
    Regards
    Thomas Olsen.
  6. #96
    Nov 2007
    PC Navigator 7 POI's
    Hi All,
    I would like to ask if anyone has had any success in editing or viewing the POI's that come with PC nav 7. I know how to import a csv file for speed cameras and create the .mef file. How do you view/edit the .mef files that already exist? I've spent hours searching the web for information with no success. It would be nice to import POI's other than speed cameras.
    Cheers
    Efful
  7. #97
    FLAC Marvin Hlavac's Avatar
    May 2005
    Recently I received PC Navigator 7 with USA/Canada map. I finally got around to installing it and driving around with it a bit. I like it. I like the 3D look. I like the automatic zoom. It's a very nice application. A few features could be improved upon, but nothing that would be a show-stopper.
    Since this one is pretty much the only discussion thread around, on the topic of PC Nav 7, I'd like to ask a couple of questions of others who have used the software more than I have:
    1) I noticed that when I enter a destination address while I'm off road (for example I'm sitting on a parking lot), the route will not be calculated. Not even when I start moving and I reach the road - the route will not automatically appear. I have to add my destination while I'm on a road. Am I doing something wrong? Are others experiencing this, too?
    2) POIs. I don't see a way to search for nearby POIs. I only see a way to search POI's by their name - but that will show them regardless of their proximity to my GPS location. Again, am I overlooking something, or is this the way the program works at this version?
    I will likely have a few other questions that will pop up later...
    Nov 2006
    Isle of Orkney. UK
    I've been using Nav 7 for a few months now. I don't think you are missing anything, I have noticed the same thing. It can take anything up to 5 minutes to calculate a route.
    As for POI's that is the way they appear to work. I'm having trouble showing poi's that I have added
    Apart from that I think it is a good program
  9. #99
    May 2005
    brodgar, thanks much for the feedback. I was driving while reading your reply, so to test again the above mentioned issue #1 I drove into the nearest large parking lot and set a new destination. It took a bit longer to calculate it, which I think was due to me not being on the road. I observed the program displayed something like "no route to destination" after I started to drive on the parking lot. I reached the road, and started to head to my destination while observing the program. This time I was more patient because you mentioned it may take several minutes. Indeed, finally it did show me a route - it took about two minutes.
    I could live with this. Also the issue #2, the POIs, is not a big deal for me, as I use POI searches only infrequently.
    So far I like the program. The map data is good. The routing seems good. The 3D-view with automatic zoom is likely the best looking out of any PC navigation program I've seen to date. This is a program worth spending time and effort on. It's interesting that no much has been written by users of the USA/Canada version, but then I guess I somehow understand - I only found I about the existence of this software few short months ago.
  10. #100
    Mar 2007
    manchester, UK
    The carpark thing is a little annoying, but it normally picks up within a minute or so of meeting the road.
    The POIs can be done, I found it whilst on holiday. It is not in an obvoius place...
  1. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  2. FS: CarPC 2.4 startup/shutdown controller
    By evilragu in forum Classified Archive
    Last Post: 03-05-2006, 05:28 PM
  3. first car pc project
    By machineshop in forum Newbie
    Last Post: 12-15-2005, 04:17 PM
  4. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
