Page 13 of 14 FirstFirst ... 34567891011121314 LastLast
Results 121 to 130 of 132
Thread: PC Navigator 7 - Europe
  1. #121
    Apr 2007
    Update on Importing Data into PCN 7.
    I was getting a crash on:
    Find and Navigate / Imported Data / <Left Click> on 'Data List Title'
    By trial and error have discovered that the Prog. does not like:
    [ ] but will accept [ ' ] as part of the fields in the data.
    Will report any further findings, but so far looks very promising.
    Best
    BTW - If we wanted to publish a list of Keyboard Entries which are recognized, how can we set it up in the Forum so that new ones can be added.
    e.g. CTRL M = Menu from Map Screen - Page Up/Down for Zoom In/Out - Arrow Keys for N/S/W/E - Tab and Arrow Keys to Navigate Menus.... - In Some Menus <Return> = Enter in others <Right Arrow> = Enter
    OR - in the words of Peggy Lee's Song - Is that all there is?
  2. #122
    May 2007
    Quote Originally Posted by Grrrmachine View Post
    Yeah, there's a volume control, which is basically a shortcut to the Windows Master Volume control. This means that if you have any music in the background, you have to configure that in balance with the deafeningly loud (in my system) level of Navigator's volumes - I have to have winamp cranked to full and then the master volume dropped to nearly zero in order to make it all sound balanced.
    Also, how do you import data? I've done a drive with Netstumbler, and I'd LOVE to have the wifi locations as POI - is there any way of doing this in Navigator?
    Yes it would be much better if you had the sound option of switching it to use an independant vol control or on the wave line instead of the master volume.
    I love the program but for these reasons i am reluctant to use it very often unless i really dont know my way somewhere!
  3. #123
    Mar 2008
    Are there any swedish voices?
    Are there any swedish voices in Navigator7?
  4. #124
    Oct 2007
    Assens, Denmark
    Found an interesting tread over at The Land Rover Forum about speedcam import in PC Nav 7:
    http://forums.lr4x4.com/index.php?sh...art=0&p=247560
    Has anybody here tried that?
    And did it work?
    @TRTR: I will check for swedish tonight and post back.
    Henrik
  5. #125
    Oct 2007
    Assens, Denmark
    Quote Originally Posted by TRTR View Post
    It has swedish text but you will have to do with either danish or norwegian voice.
    Henrik
  6. #126
    Aug 2004
    Navigator8 is out. Can't find the changes. Anyone?
  7. #127
    Nov 2006
    Isle of Orkney. UK
    I use PGPSW regularly. No problems. You have to rename the files to just cat999.mef and cat999.ttr. Works very well
  8. #128
    May 2007
    Does anyone know of a fix or if the option is available in PC Nav 8, where you can set it to use the WAVE volume line rather than the master?
  9. #129
    GTO
    GTO is offline
    Newbie GTO's Avatar
    Jul 2007
    I've imported a speed camera database but when I try to activate the warnings I get this.
    "The object data file for scout functions is missing. Please check its installation"
    Can anyone tell me what this means and how I sort this out?
    Thanks.
  10. #130
    Nov 2007
    Scout function
    Hi GTO,
    How did you import the database? I assume you imported a csv database file into exel saved the resulting xls file and then used the "getmef.exe" utility to produce a mef file.
    The mef file must be named cat999.mef and copied to the europe_ta folder.
  1. VIA and Mini-box Announce First Sub-$300 Car PC Kit
    By Goofus in forum General Hardware Discussion
    Last Post: 03-13-2006, 12:28 PM
  2. FS: CarPC 2.4 startup/shutdown controller
    By evilragu in forum Classified Archive
    Last Post: 03-05-2006, 05:28 PM
  3. first car pc project
    By machineshop in forum Newbie
    Last Post: 12-15-2005, 04:17 PM
  4. basic car pc idea
    By Joseph in forum Newbie
    Last Post: 11-08-2004, 03:04 PM
