The keycodes i have found are located in the file C:\Program Files\Navigator7\PC_Navigator\config\tyrael\defaul t_settings.xml
They are not really that much use, everything in there can be done in the GUI on the first screen i believe. But maybe some more keycode action are available, we should ask directions.
---- These are the ones that are in there. ---------
<virtualKeyBinding>
<vkCode>38</vkCode>
<action>MoveUp</action>
</virtualKeyBinding>
<virtualKeyBinding>
<vkCode>40</vkCode>
<action>MoveDown</action>
<virtualKeyBinding>
<vkCode>39</vkCode>
<action>MoveRight</action>
<virtualKeyBinding>
<vkCode>37</vkCode>
<action>MoveLeft</action>
<!-- skyway -->
<virtualKeyBinding>
<vkCode>33</vkCode>
<action>ZoomIn</action>
<virtualKeyBinding>
<vkCode>34</vkCode>
<action>ZoomOut</action>
<!-- gvox -->
<virtualKeyBinding>
<vkCode>195</vkCode>
<virtualKeyBinding>
<vkCode>196</vkCode>
<!-- magic370 -->
<virtualKeyBinding>
<vkCode>130</vkCode>
<action>Minimize</action>
<virtualKeyBinding>
<vkCode>133</vkCode>
<action>AddFavourite</action>
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
So do i, but some of the features would be nice to have available without having to go into the menu system, like 2D/3D view.
OK Guys, What am I doing wrong?
Navigator 7 Europe (Standard) arrived and was installed yesterday. My front end is iCT. I'm using Dopehead's little programme and installed it in the same directory as Nav 7. I have to run any navigation software as an external programme. No problems with that.
When I open the navigation window I now get Dopehead's programme and starting at X0/Y50 where it should, but the screen stays blank apart from a line at the bottom giving me my altitude and speed.
If I now close that window I see the map behind it which has now moved up slightly so that I can see the part of the front end behind that at top and bottom.
Any ideas ? Thanks![]()
what happens when you run it outside iCT?
You could just try and use the cmdline params directly in iCT. the only reason i have created the little appl. is because i couldn't get RoadRunner to execute pcnav with the parameters on it. It sounds like iCT is embedding my application instead of pcnav.
Been playing all morning. Run it stand alone - perfect. Nav 7 embeds nicely in PC Nav window.
The problem is obviously with iCT. I agree the front end appears to embed PC Nav but this again is only slightly better than Nav 7. At least PC Nav opens where it should, Nav 7 is full screen. But iCT will only OPEN either programme. If I switch to another screen it leaves the programme running in the background, which has to be closed separately. In the iCT ini file the only mention of navigation is for the path to the exe file. I don't know if I can add any parameters here.
I'm certain that I have PC_Nav in the correct file C:\Program Files\Navigator7\PC_Navigator.
In Nav 7 config file\tyrael folder I found the default settings doc and changed the Y co-ordinate from 0 to 50 and added two lines for window width and height but this made no difference.
I should add that I have the two latest updates as well as the Beta 7.1
At present I can run the system with the iCT bar across the top semi-opaque and covering the top half of the buttons. Not ideal, but workable
maybe you could do some screen dumps of this problem, i am having a hard time imagining this, as i don't know iCT at all.
im having a bit of trouble embbedding pc nav 7 to rr... it goes full screen and not inside the window of the gpswindow...
What settings do i need to set this up correctly?
i will create a how-to tonight, seems like it's needed now
