ok, 1st thing we need to find is whether we need the professional or the standard,do both versions allow resizing to be embedded in rr?
I have opened this thread so that we can effectively close the long running "PC navigator 6" thread.
link to company website:
http://directions.ltd.uk/laptop-navigation/
In short-
PC navigator 7 - Europe standard edition now supports being windowed, however you need to pass it some parameters, DOPEHEAD has written an executable to do this
the other intergration option that is still lacking is the ability to mute winamp when the satnav speaks. a solution to this was suggested by SERFIO
On the whole I have been impressed so far. It has not yet taken me on a obscure route, or got me lost.
one small niggle is when running in a small window the icons/ fonts are not always resized, so for instance when you do a search for your GPS com port, the details of the com port are printed below the bottom of the screen. I will report this in today and see if we get a patch.
CarPuter Progress:
Planning:-----> [||||||||||] 100%
Hardware Buying:-> [||||||||||] 100%
Software:-----> [||||||||||] 100%
Installing:-----> [||||||||||] 100%
Current Project= Making skins in photoshop...
i have the standard, and this allows me to resize (as stated above)
dopehead has the proffesional which also does
AFAIK - the difference between the standard and the proffesional is that the proffesional allows you to write your own active X front end, but as no doubt dopehead will elaborate on, this is a long arduous task.
oh yes, for it to work in RR, using the BMV2 skin, i needed to select the GPS product as external, and add a clear window (a clip) with the same size window as you are running pcnav. this allows you to see the programme through the skin.
Also, it would be nice to know if there are more keyboard shortcuts than the one i found in the new version 7 (sse old thread), maybe ogradka who initially put up the link for the patch could tell us ?
Oh, and this is the patch for Pcnav7 to get windowed support. http://static.mapfactor.com/files/pc...h-7_1_13-1.exe
Transflective Lilliput 8", LV-677DC Core Duo 1,83Ghz, , Mpegbox uSDC20D, Shuttle Express, HQCT, PG XS6600 http://carpc.boyakasha.dk
CarPuter Progress:
