I'm having the same issue. :help:
I've been messing around with settings in the file 'default_settings.xml' as well, but up untill now no results what so ever.
Anyone a solution?
Printable View
Anyone a solution?
i found a temporary solution:
shutdown in stead of hibernate. i'm not completly happy with this, but works for me, till a better solution pops up.
Hey.
Did anyone find a solution for the hibernation problem??
Completely shutting down and starting takes to much time!
Greetz,
Bunny.
What's the trick?
Whenever I save routes or journeys (as example 'gps-090914-1427', PC Navigator won't replay because it can't find the above file as .NMEA.
In the manual I read 'Select where to save the journey file, either Storage card or Object Store',
what's the trick how to select Storage card because I see no buttons on the screen.
Thanks for your reply,
gr.
Zebravink
What's the trick how to save journey's in Mapfactor?
Whenever I try to replay saved journeys, Mapfactor can't find the for example 'gps-090914'-file. What's the trick how to save and how/where to open?
Thanks for your reply.
gr.
Zebravink
I don't mean to open up a dead thread, but I'm working with the nav 12 and am trying to figure out how to embed this into my xml. Does anyone have the coded needed to embed I got the path and everything from pcnav, but I'm not sure what I need to put around the c:/.... path.
