Page 13 of 17 FirstFirst ... 34567891011121314151617 LastLast
Results 121 to 130 of 163
Thread: Media Engine - VBcoded vehicle mp3 interface + source
  1. #121
    Nov 2002
    hey I'm in the process of building my car computer as we speak and your interface solves just about all my problems. One thing I would like to see is support for the cadet AM/FM tuner card like Gutter did in Impee then I think you would truley have a great program on your hands. I'm not a programmer and I'm not sure how hard this would be to implement but possibly if gutter doesn't mind you could use some of his source code to implement it since he's gone thru the work already of interfacing it
    P.S. you show that u updated the program 11-7 but the latest download off your server is from 11-1 and has different release notes from what you listed above
  2. #122
    May 2002
    The newest version of your software took over my computer. Task bar was gone desktop icons gone. I had to go through Windows Task Manager than though folder to run system restore.
  3. #123
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    heh.. yeah.. There is an option in settings to replace the default windows shell with media Engine... Useful in a car environment.. You can switch back and forth with it. make sure it is unclicked to keep media engine from "taking over"
    Get MediaEngine !!!
    Media Engine Download
  4. #124
    Oct 2002
    Alaska
    Dexter172 - This is because the "Set Media Engine As Default Shell" option was enabled on setup. If this happens again, all you need to do is double click the clock, and on the "directories and Startup" tab uncheck the "Set Media Engine As Default Shell" box.
    Hope that helps you out.
    -Drew
  5. #125
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I have a old version cause I can't find that option.
    When I was installing it said version 1.3.5
    Can someone point me to where I can find 1.4.0?
    Thanks.
    SP13000|M2-ATX|512MB DDR400|2.5" 7200RPM S-ATA|Trans-7"|Slim SL DVD-CDRW|KEH 5.1 DSP|SB L!ve Ext|Gyration PowerMate|BT|WiFi|GPS|WinXP|VoomPC
    GPSing - Digital Speedo
    Relocating headunit and extending faceplate
    Button app to Alt-Tab between two programs
  6. #126
    Oct 2002
    Alaska
    Sure thing, the latest public releases can be found here:
    http://www.zcentric.com/~mitcht/download/
    -Drew
  7. #127
    Jan 2002
    Long Island, NY
    I can only see version 1.4.1 and I installed it and see version 1.3.5 during installation screens.
    Also no option for it as the startup shell. Maybe becasue I'm using XP?
    Nov 1st is the date of the file I got.
  8. #128
    Oct 2002
    Greensboro, NC
    I am having the same problem
    DigitalDub
    1200 mhz duron/ 384m pc133/ 6.4 gig for OS / 75 gig storage/ 32 meg Nvidia Geforce2 wit TV out / onboard sound / GPRS / 7" digitallww flip out / X10 Mouseremote / 255w inverter (temp)
    Audio
    Nakamichi CD-45Z HU / Monsoon amp and 8 speakers
  9. #129
    Jan 2002
    Long Island, NY
    What problem Superfly?
    The version 1.4.1 saying 1.3.5 during install?
    or
    No option for Media Engine as startup shell since I have Windows XP OS?
  10. #130
    Oct 2002
    Greensboro, NC
    lol, sorry about that....
    Thats my issue
    DigitalDub
    Audio
