Results 1 to 10 of 20
Thread: Media Engine 1.6.8 Available for download
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    Fixed a lot of stuff that was causing people headaches.. Also, cleaned up the way everything looks, and also volume control is MUCH more user friendly.
    Mostly visual enhancements on this build. A lot of code is cleaned up and a lot of bugs fixed.
    DON'T FORGET TO UNINSTALL YOUR LAST COPY AND DELETE \ RENAME THE C:\MediaEngine DIRECTORY>>> Failure to do this can cause things to work strangely.
    Media Engine 1.6.8 Download
    Get MediaEngine !!!
    Media Engine Download
    Oct 2001
    Indiana
    I don't understand what you mean...
    Get MediaEngine !!!
    Dec 2001
    Ok if i start viusualization with the keyboard.. (i just edited ur ini file for kb) it seems to hide mediaengine and when i exit visualization media engine is no longer there and i have to ctrl alt delete it... any way around htis to get media engine to reload or not hide itself at all??
    also it plays divxs like 20 times slowet rthen it should any fix to that?? maybe not using wma playeer and using what autoplay uses??
    am i suppoose to use extensions to play divx cuz i click extension on the menu and nothign happens yet in the setup thing i clicked play divx and dvd there..
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Not really a problem, but I'm a bit confused about the color values in colors.ini. Are they RGB values?
    Thanks in advance.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    And try as I might I cannot get the extensions menu to do anything. I have the appropriate boxes checked @ the config screen and they ARE in the settings.ini file.
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Oh yeah 2 more things. I have the visualizations problems as well ... once I exit the visualizations screen there is no more Media Player. Hmm....
    Codecs. IT can't seem to play the same media files that all the apps on my computer can. Says cannot find the codec. Do I need to install them into a directory just for media engine?
    Also the color thing. I can't figure out the values (still) and can only get basic colors (through blind *** trial and error).
    Anyways enough *****ing. This is one good app. So customizable (is that a word?).
    Oct 2001
    Indiana
    About the visualization from keyboard thing... The reason that box is grayed out is because the only reliable way to regain control of Media Engine is with a remote control IR system. Media engine Unloads the "visual part" of itself and loads the vis, but leaves winamp running. The "backbone" part of Media Engine cannot monitor the keystrokes, since they are directed towards the vis. Therefor, media engine can never "reload" the visual part of itself.
    Extensions do nothing. I disabled them, but never told anyone. I have not had a chance to mess with them, b/c I have been busy trying to get the music part of media engine just right.
    When playing DivX movies... I have not noticed the "slowdown" thing happen. I assume you have installed the divx codec. I am not very knowledgable about divx, but I thought that if the codec was installed, and you had the filename called "AVI", it would work. Guess I am wrong. I need help on this..
    The colors #s are generated by the Windows ChooseColor API call...
    (Private Declare Function ChooseColor Lib "COMDLG32.DLL" Alias "ChooseColorA" _
    (Color As TCHOOSECOLOR) As Long)
    Anyways, whatever values that come from this, Media Engine uses them the same way it uses the pre-generated windows handle numbers. They don't seem to correspond to anything. If you want, I can make a "color # maker" program.
    Get MediaEngine !!!
    ddt
    ddt is offline
    FLAC ddt's Avatar
    Aug 2002
    Just to let you know the movie opens and plays in windows media player 8, and winamp 3's video player.
    Sep 2000
    LA, CA, USA
    Here are some photos of ME in action
    Link
