Results 1 to 3 of 3
Thread: Autosync?
    Apr 2002
    South Coast, UK
    Autosync?
    Can someone tell me what the autosync does? Does it happen automatically, or do I have to manually run it from the setup window?
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    Yes, you must run it from the setup window. Its only useful if you have a network connected to your car pc (when at home). It lets you update your car from either in the house (with the autosync.exe) or from the car with the setup window. Autosync only synchronizes what is different, and only things that are not alike on the carPC. If something is on the carpc that is not on the home pc, it won't end up on the home pc.
    Get MediaEngine !!!
    Media Engine Download
    Apr 2002
    South Coast, UK
    I use those USB Pen Drives to copy mp3s to the car, so the the same routine can be used. Its just a pain having to leave the FSUI to use the setup window using a remote.
