Results 1 to 5 of 5
Thread: Error - First Time Use: Choose Display Playlist
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Hi,
    I am using 1.76 and when I go to the MP3 option I get the above..
    Very strange - any ideas any body.
    Thanks In Advance
    Terran
    Jan 2003
    Ruston, LA
    Happens with everybody, use the plalist option and select a file first. Will play correctly from then on out
    Apr 2000
    Little Rock, Arkansas
    it happens when you first start the software for the first time. If it does it everytime you start it up then you might check to see if you have your hard drive read only or if for some reason its not creating the settings.ini file.
    The Grand aMP3 Project
    Car: 96 Pontiac Grand Am
    Current Setup: AMD K62 300MHz, 64MB DIMM RAM, 20GB WD Hard Drive, Basic Video & Sound
    Jan 2003
    Thumbs up
    Doh ! Thanks that worked.
    Ayce
    Jan 2003
    Ruston, LA
    works everytime
