Results 1 to 10 of 12
Thread: TV control?
    Apr 2002
    socal
    TV control?
    Is there going to be any tv control support in Media Engine? I currently have a usb hauppauge tv/fm tuner and using the software supplied with it. It would be really nice if media engine can be a front end and control this.
    Variable Bitrate felix99's Avatar
    Apr 2002
    Europe
    would be cool - as likely all actual tv cards are WDM of WFV driver based - I also have tv in car and i'm waiting for this function
    =>> Carpc Version2 -- Epia M 10K based<<=
    ::Epia M10k,7"VGA/40GB2.5",GPS,Opus90W ::
    ::trying to build second low cost carpc::
    ::Automp3.de :: CAR= Renault Clio2 - 2 seats 1.9D
    Apr 2002
    South Coast, UK
    I got some code in VB (only 44 lines!) that can capture and display TV on screen using the avicap32.dll supplied with windows to capture from any WDM card. Ill try it out when I get a minute.
    (=========-) 99% complete
    AMD K6/2 500 @ 450mhz to keep heat and power usage down, 64Mb, slim CDrom drive, 64mb USB pendrive for MP3 transfer, 10Gb 2.5" drive for MP3, USB>RS232
    All jammed in external CDROM drive case.
    Kenwood KVC-1000r In-Dash LCD. x-10 MouseRemote. Destinator V2 Gps. DC-DC with onboard Shutdown controller.
    Maximum Bitrate 00CericaRuss's Avatar
    Jul 2002
    San Rafael, CA, USA
    nice!
    can't wait to get my xenarc so i can start running media engine in my car (cobraIII obviously won't work w/a touch screen properly)
    Apr 2002
    Europe
    thanks phil
    Apr 2002
    South Coast, UK
    Hmm, its a bit slow. Only displays roughly 10fps. I will have a look around for some better code. I would attach the exe here but you cant have attachments anymore.
    Apr 2002
    South Coast, UK
    Ok, so none of the code I have found in VB is quick enough to display TV properly. Does anyone know of a FREE OCX that will display the preview pin of WDM capture cards?
    FLAC LESLIEx317537's Avatar
    Jan 2002
    Long Island, NY
    I had really bad luck with TV reception in my car using a USB ATi.
    I live in the NY area also, so the signals are pretty strong I should suppose.
    Even if I could watch TV, it would be only 4 channels.
    I wish it worked better, so I took it out.
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    plus you'd have an awful time with reception while driving. I don't think any antena would get perfect reception. I have a tv tuner in my setup and I only use the tv while stuck in traffic or while tailgating.
    '98 Explorer Sport
    80% done
    Apr 2002
    socal
    On my setup, I get pretty decent signal while driving, I am using it through the same antenna as my fm which is amplified. While parked I get perfect reception.
    phil, I hope you can get this done at one point, I really want to use my tv tuner in ME
