Results 1 to 4 of 4
Thread: Problems with Skin Maker
    Newbie jes380's Avatar
    Apr 2003
    El Salvador
    Unhappy Problems with Skin Maker
    Hi everyone... I've been trying to make a new skin with a cool background i found... I have already created the main page and configured fonts, icons, colors, etc. I also added background to the play mp3 and playlist page... but if i click on any of the buttons on main screen, a red screen comes out with an error message. When i look at the log this is what i find:
    5/6/2003 9:38:44 PM Error occured in Playmp3.Form_Load : Invalid property value : Error number 380
    5/6/2003 9:38:44 PM An error occured in mediaengine.runok : Object was unloaded : Error number 364
    5/6/2003 9:38:57 PM An error occured in playlists.Form_Load : Invalid property value : Error number 380
    5/6/2003 9:38:57 PM An error occured in mediaengine.runok : Object was unloaded : Error number 364
    5/6/2003 9:39:04 PM An error occured in playlists.Form_Load : Invalid property value : Error number 380
    5/6/2003 9:39:04 PM An error occured in mediaengine.runok : Object was unloaded : Error number 364
    5/6/2003 9:43:11 PM An error occured in playlists.Form_Load : Invalid property value : Error number 380
    5/6/2003 9:43:11 PM An error occured in mediaengine.runok : Object was unloaded : Error number 364
    5/6/2003 9:45:28 PM Error occured in Playmp3.Form_Load : Invalid property value : Error number 380
    5/6/2003 9:45:28 PM An error occured in mediaengine.runok : Object was unloaded : Error number 364
    5/6/2003 9:50:28 PM Error occured in Playmp3.Form_Load : Invalid property value : Error number 380
    5/6/2003 9:50:28 PM An error occured in mediaengine.runok : Object was unloaded : Error number 364
    I have started over, changed icons, changed settings and nothing seems to fix it... Anyone has an idea of what the problem could be? i dont know what the error numbers mean I would realy appreciate if you can help me out... Thanks.
    JES380
    Raw Wave hijinks21's Avatar
    May 2002
    Albany, NY
    upgrade your mediaengine exe file. that should clear up those errors.
    http://www.zcentric.com/~mitcht/exe
    just replace the old one with that one.
    '98 Explorer Sport
    80% done
    Apr 2003
    El Salvador
    Thanks... Worked fine... i'll make some adjustments to it and i will upload the skin soon.
    May 2002
    Albany, NY
    the main problem is that skinmaker doesn't set some of the variables in the .skn file that ME use to need. I think what carcomp did in that exe is not be so strict it a var wasn't set in the .skn file.
    '98 Explorer Sport
    80% done
