Results 11 to 20 of 23
Thread: Help required for media engine
  1. #11
    FLAC Mastero's Avatar
    Aug 2001
    India
    yes i did update the exe... still no change ....
    New discovery
    VIS funtion button on screen doesnt work ....... works with key press feature... but once on the screen shows graphics then when hit the esc button on the keyboard .... Boom no more vis ...?
    Check this out
    Mastero
  2. #12
    Maximum Bitrate more mods's Avatar
    May 2003
    Atlanta, Ga.
    I also have the shut down problem with Windows Milliennium Edition. Media Engine just hangs, no shutdown at all. Its not the OS its Media Engine.
    I was told to upgrade to 2000 or XP.
  3. #13
    Maximum Bitrate CarComp's Avatar
    Oct 2001
    Indiana
    Heh. Well the mediaengine shutdown code is written per microsoft's recommendations... It works fine for me and many others... I think it is a hairy deal... You must understand that mediaengine is meant to run in a car environment on a clean PC... Perhaps..
    Get MediaEngine !!!
    Media Engine Download
  4. #14
    Jan 2003
    Ruston, LA
    Can you post the code snippet ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  5. #15
    Aug 2001
    India
    carcomp tumps up for your work !!
    I am using the ME on a clean pc with only win98(SE) on it ...
    Also the vis funtion has a problem ..... does nothing when you hit the onscreen button
    Mastero
  6. #16
    Apr 2003
    Mastero,
    Your right it probably is a ME problem, just upgrade to Win2K/WinXP.
    You'll get some other advantages such as NTFS rather than Fat32.
    In the car environment where you may get an accidental shutdown or reboot, you won't have to see scan-disk run under NTFS. This is because NTFS will hot fix all the errors on reboot. Plus, NTFS is more efficient in storage of data too(more MP3s).
    Upgrading will probably correct all your other problems too, because they wrote this for Win2K/WinXP.
    My two cents.......
  7. #17
    The Vauxhall Vectra Project ccsnet's Avatar
    Jan 2003
    Morecambe, Lancs, UK ( Just For The Moment )
    Did any one get any where with this ? I am building my own machine on my desk at the mo...I have tried ME and I have tried 98 get the same problem... either its to the windows logon screen ( wtf ? - I don't use this and yes I know I still logon in the background ) or I just get loading as a message on the screen.
    That 'loading' msg also happerns when I exit my sat nav software Destinator - it does not go back to Media E.
    I will 'possible try XP if I need to but does any one know how to set XP to logon with out any interaction ?
    Terran
  8. #18
    Jun 2003
    Rosemount, MN
    I think you can logon automatically with tweakui
  9. #19
    ob1
    ob1 is offline
    Low Bitrate ob1's Avatar
    Jun 2003
    Brisbane
    I have the shutdown problem. I started with an absolute minimum win98 install, then ran lite98 to take out the most stuff i could. I then installed ME and whenever i press the shutdown button, it brings up the windows login prompt over the top of the ME shell.
    I'm not too worried, i'll use a girder command to shutdown instead.
    cheers,
    sean.
  10. #20
    Jan 2003
    On a little looking I find if you install Tweekui you get that prob Ob1... Not sure about mine yet.
    Terran
