Results 11 to 20 of 25
Thread: media engine resolution issue?
  1. #11
    Sep 2002
    Worcester, MA
    Yea, i was fooling around with it today and tried running at higher resolutions, at 1280x1024, it fits vertically, but still cuts off the right hand side right down the middle of the radio button.
  2. #12
    Jan 2003
    Ruston, LA
    have you hooked it up to another monitor and tested yet ?
    [H]4 Life
    I'm a lesbian too.
    I am for hire!
  3. #13
    Sep 2002
    Worcester, MA
    yup, same deal. Maybe i should just whipe windows and start over.
  4. #14
    Apr 2003
    Tripped out website naevity......"Crazy bastard".....
    http://mp3car.com/upload/img/73614502.jpeg
    Anyone interested for more: (Send donation to naevity)
    http://gallery.mulcahy.org/index.phtml?path=Halloween
  5. #15
    Apr 2003
    Before you reinstall windows try uninstalling Media Engine, then re-install Media Engine and update the EXE file only.
    (That's if you haven't done that yet....)
  6. #16
    Sep 2002
    Worcester, MA
    a 1 liter bottle of fake blood from the halloweenstore gets the BEST experssions walking around worcester.
    and yea, ive reinstalled the program about 10 times now. Im gonna do a wipe/reinstall this weekend. Just get everything fresh and ready.
  7. #17
    May 2003
    Change the refresh rate. Try either 60hz or 75hz. One of those will line it up I believe.
  8. #18
    Sep 2002
    Worcester, MA
    I tried changing the refreshrate, did fix it. I tried at 60 and 75 on the lcd, and up to 85 on my 19inch CRT. Nothing.
    However, this morning i did a wipe/reinstall windows, intalled the touchscreen, downloaded media engine, installed, then copied over the fixed exe and then ran it for the first time.
    and it worked!~!
    Problem solved
  9. #19
    Jul 2003
    So Oregon
    Your global font size was causing that .......
  10. #20
    FLAC chut's Avatar
    Jul 2003
    San Antonio, TX. USA
    Changing resolutions.
    Hi folks,
    Have you tried changing your display resolution to 1024 X 768?
    if the program was originally designed at 1024 X 768 then it will look way to big at any lower resolution. Kinda like websites designed at lower resolution then you display. Thats why some of them tell you what res it was developed in. (this website will best viewed at 800 X 600) I am having the same problem now because for some reason my laptop won't display anything larger than 800 X 600 out of the aux. SVGA port on the back. Can we ask the designer of Media Engine if he has created an alternate front end at a lower resolution?
    Peter
