Setting up DSB-R100 radio w/ mediaengine
Can someone tell me how to install the DSB-R100 so it will work with media engine? I have installed it to the default directory c:\radio but mediaengine does not recognize it. I've tried installing the DSB-R100 in the mediaengine directory but with no success
Please help..
Eric
if the radio works with the included software on your computer it should work with media engine.
VENDOR - SpatialMinds
That is not entirely true. If you are running WindowsXP the default install uses a dll with a different signature than the one that MediaEngine uses and it works. The trick is to:
1. Go to DLink's support site and download the latest XP drivers.
2. Get the latest version of MediaEngine. A few older versions had a couple of bugs that have been fixed.
D-links website says they dont have drivers or support for Win XP. Maybe you can send me a link?
http://flesko.cz/radiator.htm
Those say they work with WinXP.....Anyone tried it out?
The DSB-R100 is installed on my computer and works fine except for the volume adjust but mediaengine still does not sync up with it.
Make sure that radio.dll in your Media Engine directory is registered.
What do you mean by registering? Do I need to find a register key? I know that that the radio.dll is installed but I'm not sure if it is registered.
I just did a clean install of Win2000. The Dlink USB radio works fine but still cannot be controlled with Mediaengine. The only thing Mediaengine will control is the radio volume and that is only if I open the radio before running Mediaengine. Any guesses why the radio still isn't working?
I got mine from DLINK Australia. The DLINK US website does not support this product.
Here they are...
http://www.dlink.com.au/tech/drivers...sb/dsbr100.htm
- You may not post new threads
- You may not post replies
- You may not post attachments
- You may not edit your posts
Forum Rules
